I have to pass two parameters to my converter i.e a string and an xmldocument , is it possible to pass multiparameters through xaml. I Shall be exposing the parameters as dependency properties. As a work around have already tried using multivalueConverters but it doesn't work well for my scenerio. PLease provide your valuable comments... :-)
Thanks much.
Thanks Alex it worked.
How do you want to pass these parameters to the constructor. Is the XML document a string as well (its name).
Does the RelayObject approach (as in Silverlight) works in your scenario?
<x:Array Type="{x:Type sys:Object}" x:Key="array">
<sys:String>Parameter 1</sys:String>
<sys:String>Parameter 2</sys:String>
</x:Array>
<Binding Converter="{StaticResource conv}" ConverterParameter="{StaticResource array}"/>
Alex.
