230
Summary Contents Access
Hi ,
I am using xamdatagrid in my project.
Here I wanted to get the tabular like appearance.
Grid should physically display lines between rows and columns.
Also i want sum of each column, but i dont want "sum=" i.e., I only want sum value not the text "sum="..
how to have it.
Please help me.
Bcz i wanted to get the Excel appearance.
Thank You!!!
  • 69686
    Suggested Answer
    To get the Excel look regarding the borders, you should create a style for the CellValuePresenter and set BorderBrush and BordeThickness properties.
    Regarding the Summaries, you should create a style for the Summary presenter and retemplate it.
    Here is a sample style that will not show the label of the Calculator used in the summary:
    <Style TargetType="{x:Type igDP:SummaryResultPresenter}">
                <Setter Property="Padding" Value="1,1"/>
                <Setter Property="Template">
                    <Setter.Value>
                        <ControlTemplate TargetType="{x:Type igDP:SummaryResultPresenter}">
                            <Border
    Background="{TemplateBinding Background}"
    BorderBrush="{TemplateBinding BorderBrush}"
    BorderThickness="1"
    Padding="{TemplateBinding Padding}"
    ToolTip="{Binding Path=SummaryResult.ToolTipResolved, RelativeSource={RelativeSource TemplatedParent}}">
                                <Grid Margin="2">
                                    <Grid.ColumnDefinitions>
                                        <ColumnDefinition Width="Auto"/>
                                        <ColumnDefinition Width="5*"/>
                                    </Grid.ColumnDefinitions>
                                    <TextBlock  Grid.Column="1" Foreground="BurlyWood" Text="{Binding Path=SummaryResult.Value, Mode=OneWay, RelativeSource={RelativeSource TemplatedParent}}" HorizontalAlignment="Right"/>
                                </Grid>
                            </Border>
                        </ControlTemplate>
                    </Setter.Value>
                </Setter>
                <Setter Property="Margin" Value="0,0,0,0"/>
            </Style>
    Hope this helps,
    Alex.
