When the user deletes a XamDataGrid record, a dialog box appears to confirm his deletion. I need to change the text of the message because it appears in English, and I need to translate the message into the language of the CultureInfo of the application. How can I accomplish this?
Hello Vikram,
Here is the correct link:
http://help.infragistics.com/NetAdvantage/WPF/Current/CLR4.0/?page=WPF_DataPresenter_Resource_Strings.html
Hi Stefan
The link is broken. Can you please provide the correct link?
Regards
Vikram
Hello Aditya,
Here is the working link from Alex’s post:
http://help.infragistics.com/NetAdvantage/WPF/2011.1/CLR4.0/?page=WPF_Customize_Assembly_Resource_Strings.html
Looks like the link is broken.
Can you please post the correct link
ThanksAditya
You can do that with the Customizer. Please follow this link below to see how to achieve this:
http://help.infragistics.com/Help/NetAdvantage/WPF/2008.2/CLR3.X/html/WPF_Customize_Assembly_Resource_Strings.html
You will need the DataPresenter strings.
Hope this helps,Alex.
