240
cursor flashing inside the new record
Hi all,
Is anyone know how to make the cursor flashing inside the new record or the selected record?
I using XamDatagrid version 9.1. I have a grid and also a button new and edit.
those are code I using in button new:
xamDataGrid.FieldLayoutSettings.AllowAddNew = true;
(xamDataGrid.RecordManager.CurrentAddRecord as DataRecord).Cells[xamDataGrid.FieldLayouts[0].Fields[0]].IsActive = true;
(xamDataGrid.RecordManager.CurrentAddRecord as DataRecord).Cells[xamDataGrid.FieldLayouts[0].Fields[0]].IsSelected = true;
 xamDataGrid.ExecuteCommand(DataPresenterCommands.StartEditMode);
with that code, the new record added and selected, but the cursor won't flashing in it.
It also happen if I click edit button.
those are code I using in button edit :
xamDataGrid.FieldLayoutSettings.AllowEdit = true;
(xamDataGrid.ActiveRecord as DataRecord).Cells[xamDataGrid.FieldLayouts[0].Fields[0]].IsActive = true;
(xamDataGrid.ActiveRecord as DataRecord).Cells[xamDataGrid.FieldLayouts[0].Fields[0]].IsSelected = true;
with that code, the selected record is in edit mode and selected, but the cursor won't flashing in it.
I need to click on the record first to make to cursor  flashing inside the record.
Is there anyone know how to solved this?
Thanks before,
Vera
