380
How to apply tooltip to each field programatically
Hi..I m using Xamdatagrid.xamgrid is having more than 20 columns.
here i gave columns labels as w1,w2,w3,w4 ....
Here i want to use tooltips for each field labels .But i want to apply in code.
Bec i ve to apply vaues like this .first field header tooltip  is 1 means second field header tooltip is 5 like tat.
third field header tooltip is 9 and so on..
we can apply in xaml using tooltipservice.tooltip="1"..it is working fine.but it is fixed..
but i want to appy in code..bec my tooltip values may change..based on the user input.it is not fixed.
so please give reply how to apply tooltip to each field in c# code.
here i = 1
mainDataGrid.DefaultFieldLayout.Fields[2].Tag = i.ToString();
Here no Tooltip property for field..Tag is not worked here.
Thanks in advance..
  • 69686
    Suggested Answer
    You can do this with the following code snippet:
    <Style TargetType="{x:Type igDP:LabelPresenter}">
    <Setter Property="ToolTip" Value=""/>
    <EventSetter Handler="FieldToolTipOpening" Event="ToolTipOpening"/>
     </Style>
    void FieldToolTipOpening(object sender, ToolTipEventArgs e)
                if (sender is LabelPresenter && sender != null)
                    LabelPresenter l = sender as LabelPresenter;
                    l.ToolTip = l.Field.Index.ToString() + " " + l.Field.Name.ToString();
    Hope this helps,
    Alex.
