I have a style written for the drop down which is placed in the xamdatagrid and on the initialized event of drop down i populate the control.
The dropdown's itemsource is dependent on another combox. The control in the grid needs to be repopulated on the selection changed event of this Main combo box. What i have done here is made used of the drop button click event and repopulated the drop down.
Is there a better way of acheiving the same using datatriggers?
Thanks much.
This is a good way to do this according to me.
Using DataTriggers would be a rather static approach as you have to specify the value at which the DataTrigger will fire. If you have couple of items in the Main ComboBox and they are not changing this could also work.
Alex.
