115
Disable the menu on right click of Pane and set the visibility of close button
Please look the code below.
I want to set the visibility of the close button when visibility of edit button gets changed. Line which is bold does not seems to have working.
Please suggest, also if u can let me know how to deactivate the menu on right click of pane.
igDock:ContentPane x:Class
="Eclipsys.SunriseXA.SIRI.Client.HomeScreen.WidgetPane"
xmlns
="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:igDock
="http://infragistics.com/DockManager"
xmlns:x
="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:Eclipsys_SunriseXA_PE_WPFUIControls
="clr-namespace:Eclipsys.SunriseXA.PE.WPFUIControls;assembly=Eclipsys.SunriseXA.PE.WPFUIControls">
<igDock:ContentPane.Resources
<Style TargetType="{x:Type Button}" x:Key="{x:Static igDock:PaneHeaderPresenter
.CloseButtonStyleKey}">
<Setter Property
="ContentTemplate">
<Setter.Value
<DataTemplate
<Eclipsys_SunriseXA_PE_WPFUIControls:EclpImage
ImagePath
="pack://application:,,,/Eclipsys.SunriseXA.SIRI.Client.HomeScreen;component/Images/delete.png"
ImageSize="_16x16" x:Name
="closeImage">
</Eclipsys_SunriseXA_PE_WPFUIControls:EclpImage
</DataTemplate
</Setter.Value
</Setter
<Setter Property="Background" Value
="Transparent" />
<Setter Property="BorderBrush" Value
="Transparent" />
<Setter Property="Visibility" Value="{Binding ElementName=editButton , Path=Visibility}"></Setter
</Style
.PinButtonStyleKey}">
="Collapsed"/>
</Style
<Style TargetType="{x:Type MenuItem}" x:Key="{x:Static igDock:PaneHeaderPresenter
.PositionMenuItemStyleKey}">
="Collapsed"/>
</Style
</igDock:ContentPane.Resources
<igDock:ContentPane.HeaderTemplate
<DataTemplate
<StackPanel Orientation="Horizontal" HorizontalAlignment
="Right">
<Button x:Name="editButton" Click="editButton_Click" Background="Transparent" BorderBrush
="Transparent">
<Button.Content
ImagePath
="pack://application:,,,/Eclipsys.SunriseXA.SIRI.Client.HomeScreen;component/Images/edit.png"
ImageSize
="_16x16"/>
</Button.Content
</Button
</StackPanel
</DataTemplate
</igDock:ContentPane.HeaderTemplate
igDock:ContentPane
-Toral.
