I want to plot TimeSpan data on the x axis. For everything I have tried, XamDataGrid chokes on it. Is there a way to do it?
Bill
Hi Bill,
I don't think this is possible because in your case ValueX is from long type and you are trying to format the string representation based on a TimeSpan value. However using DateTime values and the following example maybe helpful for your :
http://help.infragistics.com/Help/NetAdvantage/WPF/2008.1/CLR3.X/html/xamChart_Modifying_a_Date_Time_Axis.html
Hope this helps
Vlad
Vlad,
Is it possible for the X Axis to plot TimeSpan.Ticks as a double, and then have a ValueToDisplayTextConverter that would format Ticks to "days.hours:minutes:seconds.milliseconds"? Where in the class heirarchy can I find such a ValueToDisplayTextConverter?
I downloaded your sample and looked at it in VS. My charts are ScatterLine. I don't think I can do what you did for your Column chart. Here is some relevant xaml from my project.
<igCA:Series ChartType="ScatterLine" Label="val1" DataSource="{Binding Path=''}" DataMapping="ValueX = timeSpan; ValueY = val1" />
"val1" is a DataColumn of type double. "timeSpan" is a DataColumn of type TimeSpan.
Could you please provide more information about the type of the chart and how do you want the TimeSpan to appears (string or some value) ? In case you are using Column chart and want to display the TimeSpan elements as labels on the x axis you can take a look at my sample project.
