575
SmallImage is not resized to 16 x 16.It still shows as Large Image
I applied Small image in the application.but it shows as Large Image when i execute it.
Here is my code.
<igRibbon:XamRibbon x:Name="ribbon" Grid.Row
="0">
<igRibbon:XamRibbon.ApplicationMenu
<igRibbon:ApplicationMenu Image="Resources\Images\LogoWithoutBorders.ico" x:Name="AppMenu"
<igRibbon:ButtonTool x:Name="New" Caption="New" SmallImage="Resources\Icons\OBarCreateNew.png" IsEnabled
="False"/>
<igRibbon:ButtonTool x:Name="Query" Caption="Query" SmallImage="Resources\Images\database_lightning.png" IsEnabled
="False"/>
<igRibbon:ButtonTool x:Name="Submit" Caption="Submit" SmallImage="Resources\Icons\save.png" IsEnabled
="False"/>
<igRibbon:ButtonTool x:Name="Copy" Caption="Copy" SmallImage="Resources\Icons\EditCopy.png" IsEnabled
="False"/>
<igRibbon:ButtonTool x:Name="Delete" Caption="Delete" SmallImage="Resources\Icons\table_row_delete.png" IsEnabled
="False"/>
<igRibbon:ButtonTool x:Name="Print" Caption="Print" SmallImage="Resources\Icons\BtnPrint.png" IsEnabled
="False"/>
<igRibbon:ButtonTool x:Name="PPView" Caption="Print Preview" SmallImage="Resources\Icons\ButtonPrintPreview.png" IsEnabled
="False"/>
<igRibbon:ButtonTool x:Name="RestoreView" Caption="Restore View" SmallImage="Resources\Icons\16-image-check.png" IsEnabled
="False"/>
<igRibbon:MenuTool x:Name="Others" Caption="Others" SmallImage="Resources\Icons\24-image-add.png" IsEnabled
="False">
</igRibbon:MenuTool
<igRibbon:ButtonTool x:Name="CloseButton" Caption="Close" SmallImage="Resources\Icons\pcCloseButton.png" IsEnabled
="False"/>
<igRibbon:SeparatorTool
<igRibbon:ButtonTool x:Name="Exit" Caption="Exit" SmallImage
="Resources\Images\exit.png" />
</igRibbon:ApplicationMenu
</igRibbon:XamRibbon.ApplicationMenu
  • 27093
    When creating a ribbon there are some guidelines defined from Microsoft that should be followed. This is one of them. If you think about it you probably wont remember seeing menus with different sized icons. This is why our Ribbon doesn't differentiate between SmallImage and LargeImage proeprties when they are used in the menu. You can look into the Microsoft guidelins here: http://msdn.microsoft.com/en-us/library/cc872782.aspx#icons
    Hope this helps.
    Sincerely,
    Petar Monov
    Developer Support Engineer,
    Infragistics, Inc
