Hello.
I have a question about the XamRibbon. I have a WPF application with a ribbon. In the code behind I have an ObservableCollection of RibbonTabItems. I would like to bind this colletion to the Tabs property of the XamRibbon, but the Tabs property read only.
Is there another way to bind the XamRibbon tabs to a ObservableCollection of RibbonTabItems?
Is there another property of the XamRibbon that can be used for the binding with this collection that contains the tabs of the ribbon?
Thanks a lot.
Nico
Hello Andrew.
Thanks very much for the answer. I will add also a request for this.
Currently there is no property that you can set to provide a list of tabs. You may want to submit a suggestion for adding this in the future. For now you could add your own attached property to the xamRibbon and manage synchronizing the Tabs collection with the items from your collection.
