I have successfully modified every action of the LabelPresenter. What I have not been able to do is to modfiy the default background color when simply the mouse is over the grid label. Sorry, IsMouseOver does not work. I have tried all of the below. Image attached. The default appears as an pale Blue color. I would like to change that.
Thanks in advance.
Glenn
<Style.Triggers>
<Trigger Property="SortStatus" Value="Ascending">
<Setter Property="Background" Value="Orange"/>
<Setter Property="Foreground" Value="Black" />
</Trigger>
<Trigger Property="SortStatus" Value="Descending">
<Setter Property="Background" Value="Yellow"/>
<MultiTrigger>
<MultiTrigger.Conditions>
<Condition Property="IsMouseCaptured" Value="True" />
<Condition Property="IsMouseDirectlyOver" Value="True" />
<Condition Property="IsMouseOver" Value="True" />
<Condition Property="Selector.IsSelected" Value="True" />
<Condition Property="IsFocused" Value="True" />
</MultiTrigger.Conditions>
<Setter Property="Background" Value="{DynamicResource MOINormalBackgroundBrush}" />
</MultiTrigger>
</Style.Triggers>
Sebi,
Indeed you are correct. Thanks for the help!
The background of the cell is binded to the LabelHighlight property of the LabelPresenter.. not Background. It should work if you use LabelHighlight instead of Background.
