665
Padding and styles
If I set padding for any of the editors in a Style, the padding value is 'lost' when going into edit mode. If I set it in the control XAML line, it is applied for the edit mode also.
Any ideas how to overcome this behaviour?
  • 54937
    I think the default template has a controltemplate trigger that sets the Padding when IsEmbedded is false and control template triggers take precedence over a style setter. You would probably need to use a Style trigger to override the template trigger.
    <Style TargetType="{x:Type igEditors:XamMaskedEditor}">
        <Style.Triggers>
            <Trigger Property="IsEmbedded" Value="False">
                <Setter Property="Padding" Value="10" />
            </Trigger>
        </Style.Triggers>
    </Style>
