585
Mixing objects and nulls in XamDataGrid - Bad idea?
Looking for Clarification:
I am using a xamdatagrid and I am loading into the ObservableCollection a mixture of objects and nulls. ObservableCollection is bound to xamdatagrid. I am using nulls as placeholders. For example I will load 100 objects into the collection then 1 or more nulls depending on what i need to do. As time goes on and I add, delete, sort or whatever, I'll get "Object reference not set to an instance of an object" errors (gory details below). What I did notice is that this error popped up at different times but the target area of the details of the exception all seem to be DataRecordHolder.
Yes I do have an example and it is attached. Run the attached app after looking at the initializecomponent and click the clear button. Error listed below will follow.
So please advise? How bad is this idea?
System.NullReferenceException was unhandled
  Message="Object reference not set to an instance of an object."
  Source="Infragistics3.Wpf.DataPresenter.v9.1"
  StackTrace:
       at Infragistics.Windows.DataPresenter.RecordManager.DataRecordHolder.GetHashCode()
       at System.Collections.Hashtable.GetHash(Object key)
       at System.Collections.Hashtable.InitHash(Object key, Int32 hashsize, UInt32& seed, UInt32& incr)
       at System.Collections.Hashtable.Insert(Object key, Object nvalue, Boolean add)
       at System.Collections.Hashtable.set_Item(Object key, Object value)
       at Infragistics.Windows.DataPresenter.RecordManager.OnSourceCollectionReset()
       at Infragistics.Windows.DataPresenter.RecordManager.OnSourceCollectionChanged(Object sender, NotifyCollectionChangedEventArgs e)
       at Infragistics.Windows.DataPresenter.RecordManager.ProcessChangeNotification(Object sender, Object eventArgs)
       at Infragistics.Windows.DataPresenter.RecordManager.OnChangeNotification(Object sender, Object eventArgs, Boolean isReset)
       at Infragistics.Windows.DataPresenter.RecordManager.System.Windows.IWeakEventListener.ReceiveWeakEvent(Type managerType, Object sender, EventArgs e)
       at System.Windows.WeakEventManager.DeliverEventToList(Object sender, EventArgs args, ListenerList list)
       at System.Windows.WeakEventManager.DeliverEvent(Object sender, EventArgs args)
       at System.Collections.Specialized.CollectionChangedEventManager.OnCollectionChanged(Object sender, NotifyCollectionChangedEventArgs args)
       at System.Collections.ObjectModel.ObservableCollection`1.OnCollectionChanged(NotifyCollectionChangedEventArgs e)
       at System.Collections.ObjectModel.ObservableCollection`1.ClearItems()
       at System.Collections.ObjectModel.Collection`1.Clear()
       at WpfApplication1.Window1.ClearButton_Click(Object sender, RoutedEventArgs e) in C:\Documents and Settings\chadwhet\My Documents\Visual Studio 2008\Projects\WpfApplication1\WpfApplication1\Window1.xaml.cs:line 42
       at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
       at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
       at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
       at System.Windows.UIElement.RaiseEvent(RoutedEventArgs e)
       at System.Windows.Controls.Primitives.ButtonBase.OnClick()
       at System.Windows.Controls.Button.OnClick()
       at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
       at System.Windows.UIElement.OnMouseLeftButtonUpThunk(Object sender, MouseButtonEventArgs e)
       at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
       at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
       at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
       at System.Windows.UIElement.CrackMouseButtonEventAndReRaiseEvent(DependencyObject sender, MouseButtonEventArgs e)
       at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
       at System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted)
       at System.Windows.Input.InputManager.ProcessStagingArea()
       at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
       at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
       at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
       at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
       at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
       at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
       at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
       at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter)
       at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler)
       at System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler)
       at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Boolean isSingleParameter)
       at System.Windows.Threading.Dispatcher.Invoke(DispatcherPriority priority, Delegate method, Object arg)
       at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
       at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
       at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
       at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
       at System.Windows.Threading.Dispatcher.Run()
       at System.Windows.Application.RunDispatcher(Object ignore)
       at System.Windows.Application.RunInternal(Window window)
       at System.Windows.Application.Run(Window window)
       at System.Windows.Application.Run()
       at WpfApplication1.App.Main() in C:\Documents and Settings\chadwhet\My Documents\Visual Studio 2008\Projects\WpfApplication1\WpfApplication1\obj\Debug\App.g.cs:line 0
       at System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args)
       at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
       at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
       at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
       at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
       at System.Threading.ThreadHelper.ThreadStart()
  InnerException:
WpfApplication1.zip
