305
Shared columns with subrows?
I have hierarchy which is of 2 different objects with the same relevant  fields. One object contains the other. When I expand the subrow to see the second object it works, only it has its properties in its own columns. Since the properties I'm showing for both objects are the same, I think it's redundant to show the column names two times. The attached picture will help illustrate my point.
My question is: Is there away that both the row and subrow can share the same columns?
 Thanks!
  • 69686
    To the best of my knowledge that is not possible. The LabelLocation property is set for a field layout. Another option is to set the Visibility property of the LabelPresenter to Collapsed where you do not want to be a label.
