1921
Cell Value not updating when auto expanded
Alex,
Long long ago i raised an issue regarding, the cell value not get updating when the underlying
object get change. I created a solution for reproduce that issue and attached with this post.
Please check it.
Step to reproduce:
1. Run the program.  (The grid will appear with expanded child records)
2. Click th the 'Change mark' button (three or more time). This time the underlying value is changing but
the value not reflecting in cells. (the First record should change but not happen)
3. Now just collapse the first record and expand the same (using  expandable Record -  or +)
4. Now You can see the actual value.
5. Hereafter whenever you click the 'Change mark' button the value getting update properly.
How is this? is any problem with my code?
Sorry for long post.
Ramesh.P
CellValueNotUpdateReproduce.zip
