I have a hierarchical dataset bound as the datasource to a datagrid. The rows in the parent table show up in the grid, and all the rows have an expansion indicator on their left. However, some of the rows in my datasource do not have corresponding rows in the child table. For these, I don't want the expansion indicator to appear, so that the user can easily tell which rows have children and which do not. Is this possible?
thanks,
- Kam
Nevermind. It was my own fault here...
There is also the reverse of this situation: you have an editable grid with AddNew rows and I expected parent rows with no children to show the plus sign and when clicked, to expand to an empty add new record row. But it doesn't happen. The plus sign just disappears when clicked.
Anyone know a solution for this?
JohnFrench said: Here is the call stack
Andrew, I can't post the project but here is my grid definition
="xamDataGridOL_InitializeRecord">
igDP:XamDataGrid>
I am using code very similar to the article "Binding to a Hierarchical SQL Database" to source my data i.e.
flatData = New DataSet("flatData")
sqlConnection1 =
New SqlConnection("Data Source=BIOVPC;Initial Catalog=" & _
"DarwinApp;Integrated Security=True")
sqlSelectCommand1 =
New SqlCommand("SELECT KeyPrefix,ObjTypeDescr," & _
"CAST(ObjTypeID AS INT) " & _"AS aTypeID FROM ObjectType ORDER BY ObjTypeDescr")
sqlSelectCommand1.Connection = sqlConnection1
sqlDataAdapter1 =
New SqlDataAdapter
sqlDataAdapter1.SelectCommand = sqlSelectCommand1
sqlConnection2 =
sqlSelectCommand2 =
New SqlCommand("SELECT ObjKey,ObjName,CAST(ObjTypeID AS INT) "
& _"AS bTypeID FROM ObjectLibrary ORDER BY ObjName")
sqlSelectCommand2.Connection = sqlConnection2
sqlDataAdapter2 =
sqlDataAdapter2.SelectCommand = sqlSelectCommand2
sqlDataAdapter1.Fill(flatData.Tables.Add(
"ObjTypes"))
sqlDataAdapter2.Fill(flatData.Tables.Add(
"ObjLibrary"))
tblRelation =
New DataRelation("Hierarchy", _flatData.Tables("ObjTypes").Columns("aTypeID"), _
flatData.Tables(
"ObjLibrary").Columns("bTypeID"))
flatData.Relations.Add(tblRelation)
Me.xamDataGridOL.DataSource = flatData.Tables(0).DefaultView
note that there are a few line continuation characters out of place in the above (cut and paste issues).
In the FieldLayoutInitialized Event Handler I have the following
e.FieldLayout.Fields(
"aTypeID").Visibility = Visibility.Hidden
and am just trying to work out how to hide the bTypeID column!
I am new to your controls if that has any bearing on the issue. .
at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) at System.Delegate.DynamicInvokeImpl(Object[] args) at System.Windows.RoutedEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget) at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target) at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs) at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args) at System.Windows.UIElement.RaiseEvent(RoutedEventArgs e) at Infragistics.Windows.DataPresenter.DataPresenterBase.OnInitializeRecord(InitializeRecordEventArgs args) at Infragistics.Windows.DataPresenter.DataPresenterBase.RaiseInitializeRecord(Record record) at Infragistics.Windows.DataPresenter.Record.FireInitializeRecord() at Infragistics.Windows.DataPresenter.MainRecordSparseArray.OnItemCreated(Object item, Int32 index) at Infragistics.Windows.Helpers.SparseArray.CreateItemHelper(ICreateItemCallback createItemCallback, Node node, Int32 nodeIndex, Int32 overallIndex) at Infragistics.Windows.Helpers.SparseArray.GetItemAtVisibleIndex(Int32 visibleIndex, ICreateItemCallback createItemCallback) at Infragistics.Windows.DataPresenter.MainRecordSparseArray.GetItemAtVisibleIndex(Int32 visibleIndex) at Infragistics.Windows.DataPresenter.ViewableRecordCollection.GetItem(Int32 index) at Infragistics.Windows.DataPresenter.ViewableRecordCollection.VisualRecordEnumerator.MoveNext() at System.Windows.Data.CollectionView..ctor(IEnumerable collection, Int32 moveToFirst) at System.Windows.Data.ListCollectionView..ctor(IList list) at MS.Internal.Data.ViewManager.GetViewRecord(Object collection, CollectionViewSource cvs, Type collectionViewType, Boolean createView) at MS.Internal.Data.DataBindEngine.GetViewRecord(Object collection, CollectionViewSource key, Type collectionViewType, Boolean createView) at System.Windows.Data.CollectionViewSource.GetDefaultCollectionView(Object source, Boolean createView) at System.Windows.Data.CollectionViewSource.GetDefaultCollectionView(Object source, DependencyObject d) at System.Windows.Controls.ItemCollection.SetItemsSource(IEnumerable value) at System.Windows.Controls.ItemsControl.OnItemsSourceChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at Infragistics.Windows.Virtualization.RecyclingItemsControl.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, OperationType operationType) at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, OperationType operationType, Boolean isInternal) at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value) at System.Windows.Data.BindingOperations.SetBinding(DependencyObject target, DependencyProperty dp, BindingBase binding) at System.Windows.FrameworkElement.SetBinding(DependencyProperty dp, BindingBase binding) at Infragistics.Windows.DataPresenter.DataPresenterBase.InitializeRecordListControlPanel(RecordListControl rlc, Type panelType) at Infragistics.Windows.DataPresenter.DataPresenterBase.InitializeItemsPanel() at Infragistics.Windows.DataPresenter.DataPresenterBase.InitializeRecordManagerDataSource() at Infragistics.Windows.DataPresenter.DataPresenterBase.get_CurrentRecordListControl() at Infragistics.Windows.DataPresenter.DataPresenterBase.VerifyContentSiteGrid() at Infragistics.Windows.DataPresenter.DataPresenterBase.OnApplyTemplate() at System.Windows.FrameworkElement.ApplyTemplate() at System.Windows.FrameworkElement.MeasureCore(Size availableSize) at System.Windows.UIElement.Measure(Size availableSize) at MS.Internal.Helper.MeasureElementWithSingleChild(UIElement element, Size constraint) at System.Windows.Controls.ContentPresenter.MeasureOverride(Size constraint) at System.Windows.FrameworkElement.MeasureCore(Size availableSize) at System.Windows.UIElement.Measure(Size availableSize) at System.Windows.Controls.DockPanel.MeasureOverride(Size constraint) at System.Windows.FrameworkElement.MeasureCore(Size availableSize) at System.Windows.UIElement.Measure(Size availableSize) at System.Windows.Controls.Border.MeasureOverride(Size constraint) at System.Windows.FrameworkElement.MeasureCore(Size availableSize) at System.Windows.UIElement.Measure(Size availableSize) at System.Windows.Controls.Control.MeasureOverride(Size constraint) at System.Windows.FrameworkElement.MeasureCore(Size availableSize) at System.Windows.UIElement.Measure(Size availableSize) at System.Windows.Controls.StackPanel.MeasureOverride(Size constraint) at System.Windows.FrameworkElement.MeasureCore(Size availableSize) at System.Windows.UIElement.Measure(Size availableSize) at MS.Internal.Helper.MeasureElementWithSingleChild(UIElement element, Size constraint) at System.Windows.Controls.ContentPresenter.MeasureOverride(Size constraint) at System.Windows.FrameworkElement.MeasureCore(Size availableSize) at System.Windows.UIElement.Measure(Size availableSize) at System.Windows.ContextLayoutManager.UpdateLayout() at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object arg) at System.Windows.Media.MediaContext.InvokeOnRenderCallback.DoWork() at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks() at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget) at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget) at System.Windows.Media.MediaContext.Resize(ICompositionTarget resizedCompositionTarget) at System.Windows.Interop.HwndTarget.OnResize() at System.Windows.Interop.HwndTarget.HandleMessage(Int32 msg, IntPtr wparam, IntPtr lparam) at System.Windows.Interop.HwndSource.HwndTargetFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) at System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Boolean isSingleParameter) at System.Windows.Threading.Dispatcher.Invoke(DispatcherPriority priority, Delegate method, Object arg) at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) at MS.Win32.UnsafeNativeMethods.CallWindowProc(IntPtr wndProc, IntPtr hWnd, Int32 msg, IntPtr wParam, IntPtr lParam) at MS.Win32.HwndSubclass.DefWndProcWrapper(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) at MS.Win32.UnsafeNativeMethods.CallWindowProc(IntPtr wndProc, IntPtr hWnd, Int32 msg, IntPtr wParam, IntPtr lParam) at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) at Infragistics.Windows.Ribbon.NativeWindowMethods.SetWindowRgn(IntPtr hWnd, IntPtr hRgn, Boolean bRedraw) at Infragistics.Windows.Ribbon.NativeWindowMethods.SetWindowRgnApi(IntPtr hWnd, IntPtr hRgn, Boolean bRedraw) at Infragistics.Windows.Ribbon.XamRibbonWindow.UpdateWindowClipRegion(IntPtr newRegion) at Infragistics.Windows.Ribbon.XamRibbonWindow.UpdateWindowClipRegion() at Infragistics.Windows.Ribbon.XamRibbonWindow.OnSourceInitialized(EventArgs e) at System.Windows.Window.CreateSourceWindowImpl() at System.Windows.Window.SafeCreateWindow() at System.Windows.Window.ShowHelper(Object booleanBox) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) at System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) at System.Windows.Threading.DispatcherOperation.InvokeImpl() at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state) at System.Threading.ExecutionContext.runTryCode(Object userData) at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Threading.DispatcherOperation.Invoke() at System.Windows.Threading.Dispatcher.ProcessQueue() at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) at System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Boolean isSingleParameter) at System.Windows.Threading.Dispatcher.Invoke(DispatcherPriority priority, Delegate method, Object arg) at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg) at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame) at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame) at System.Windows.Threading.Dispatcher.Run() at System.Windows.Application.RunDispatcher(Object ignore) at System.Windows.Application.RunInternal(Window window) at System.Windows.Application.Run(Window window) at System.Windows.Application.Run() at DarwinWPF.Application.Main() at System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args) at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args) at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly() at System.Threading.ThreadHelper.ThreadStart_Context(Object state) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ThreadHelper.ThreadStart()
Let me know if you need anything else.
John
Can you provide the callstack for the exception? It would also be helpful if can you post a project that demonstrates the issue.
