I am assigning a datatable to xamdatagrid's datasource. the datatable contains decimal numbers (both positive and negative). unfortunately, the negative numbers are shown as blank. I guess I made some format on top of the data (for removing $ symbol before the numbers), and this could be the reason. Below is the code that prevents the $ symbol to be shown.
Infragistics.Windows.Editors.
Can anyone help me how to show negative numbers by keeping this format?
Thanks in advance.
Ganesh.
I figured it out. I needed to set the Format and not the Mask in the setter.
This doesn't work for me. This concept of styling a value in a cell is difficult to understand. There are
I have this XAML and the data is a double but the formatted value is weird. A negative double value doesn't show up at all, a poitive double value shows up as a really weird value such as $134,940.00;($9,000)
<igDP:Field Name="Col5" Label="BASE YEAR BUDGET"> <igDP:Field.Settings> <igDP:FieldSettings AllowEdit="False" EditorType="{x:Type igEditors:XamCurrencyEditor}"> <igDP:FieldSettings.EditorStyle> <Style TargetType="{x:Type igEditors:XamCurrencyEditor}" > <Setter Property="Mask" Value="$###,##0.00;($###,##0.00)" /> </Style> </igDP:FieldSettings.EditorStyle> </igDP:FieldSettings> </igDP:Field.Settings> </igDP:Field>
Strangley, if I use this XAML:
<igDP:Field Name="Col6" Label="FUNDING"> <igDP:Field.Settings> <igDP:FieldSettings AllowEdit="False" EditAsType="{x:Type sys:Decimal}"/> </igDP:Field.Settings> </igDP:Field>
The field displays almost as I want it. It shows as a currency value $123.00 or -$123.00.
Why would setting the EditAsType affect the display of a readonly field? Shouldn't there be a property named DisplayAsType or something like that?
I believe this is the same issue here
How can I keep the currency formattng for a negative number?
I'd like to get parens around the number if it is negative. So that -123.88 appears as $(128.88)
Hi Alex,
Thanks for the reply. Yes I have placed the mask and is working fine now.
Ganesh
