Good day all.
I need to do something, but I have the feeling it is not possible...
We have a grid with processes. I need to change the state (defined in a code list), but the processes don't all have the same possible states.
Process A can change to state reject or complete
Process B can change to state Rework, blank, in progress and complete.
Can I change this code
<igEditors:ComboBoxItemsProvider x:Key="cbFKState" ItemsSource="{Binding Source={StaticResource odpHotworkS_State}}" DisplayMemberPath="State" ValuePath="IdState"> </igEditors:ComboBoxItemsProvider>
to enable it to use a different ItemSource, depending on the activeRecord?
Regards
Christo
Hi Alex.
Like always, a quick and accurate reply. I was able to implement it as you instructed. I'm just adding the function to complete the thread. Thank you again for your help!
private void xamDataGridHotwork_Progress_CellActivated(object sender, Infragistics.Windows.DataPresenter.Events.CellActivatedEventArgs e) { if (e.Cell.Field.Label.ToString() == "State") { Cell activeCell = e.Cell; XamComboEditor myComboEditor = (XamComboEditor)CellValuePresenter.FromCell(activeCell).Editor; ComboBoxItemsProvider myCBitemsProvider = new ComboBoxItemsProvider(); ObjectDataProvider odb = (ObjectDataProvider)(this.Resources["odpHotwork_StateChanges"]); odb.MethodName = "GetStateChanges"; odb.MethodParameters.Clear(); odb.MethodParameters.Add(_idFlow); odb.Refresh(); HotworkDAL.Hotwork_StateChangesDataTable dt_state = (HotworkDAL.Hotwork_StateChangesDataTable)odb.Data; foreach (HotworkDAL.Hotwork_StateChangesRow row in dt_state) myCBitemsProvider.Items.Add(row); myCBitemsProvider.DisplayMemberPath = "State"; myCBitemsProvider.ValuePath = "IdFlow"; myComboEditor.DropDownClosed += new EventHandler<RoutedEventArgs>(myComboEditor_DropDownClosed); myComboEditor.ItemsProvider = myCBitemsProvider; } }
Hello Christo,
You can do that. The CellValuePresenter exposes an Editor property which will return an instance of the editor in that cell. You can cast that to a XamComboEditor and then change its ItemsSource property accordingly.
You may also find helpful our methods Infragistics.Windows.Utilities.Get(Ancestor/Descendant)From(Type/Name) to go up/down the element tree and search for elements.
