I get the following Xaml Binding error in my Visual Studio output window when starting my application. XamDatagrid version is 9.1.20091.2049. Do you know what it means? Thanks.
System.Windows.Data Error: 39 : BindingExpression path error: 'RecordFilters' property not found on 'object' ''FieldLayout' (HashCode=3465296)'. BindingExpression:Path=RecordFilters.Version; DataItem='FieldLayout' (HashCode=3465296); target element is 'PropertyValueTracker' (HashCode=21720596); target property is 'Target' (type 'Object')
In the xaml code that you have provided I do not see anywhere a binding to the RecordFilters, which makes me think that you are using the Express version of our WPF package. If that is so, please note that the Record Filtering as well as all the new features are no included in the express version.
Hello bsword,
This may have to do with the fact that there is no DataContext set. I would suggest that if you require further assistance with this issue that you please submit a support request: http://ko.infragistics.com/support/submitrequest.aspx
I'm not actualy trying to bind to those fields. I've attached my Xaml file.
Hi bsword,
There may be a couple things going on here but one specifically that will interfere with your binding is that the RecordFilters property is not a dependency property.
Also, the FieldLayout is not an actual visual element in the visual tree. Both of theses aspects will prevent you from binding to this object in this way.
What is the use case that you are trying to accomplish and maybe we can provide you with an alternate solution?
