235
DocumentContentHost tab cut off
Hi
I am having problems on the initial load of a TabGroupPane in a DocumentContentHost. The tab with focus is badly clipped on the right hand end (see image below). I have tried this in many different configurations but to some extent the problem remains. This only applies if the tab strip alignment is set to top.
Here is the code:
<Window x:Class="Test.Main"
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    xmlns:vgm="clr-namespace:Test"
    Title="Main" Name="winMain" WindowState="Maximized" WindowStyle="SingleBorderWindow" xmlns:igDock="http://infragistics.com/DockManager" xmlns:igOutlookBar="http://infragistics.com/OutlookBar" xmlns:my="clr-namespace:Infragistics.Windows.Editors;assembly=Infragistics3.Wpf.Editors.v9.1" xmlns:igRibbon="http://infragistics.com/Ribbon">
    <Grid Background="#FFEDF4FD" Margin="0,0,0,0">
        <Grid.RowDefinitions>
            <RowDefinition Height="24"></RowDefinition>
            <RowDefinition Height="40"></RowDefinition>
            <RowDefinition></RowDefinition>
        </Grid.RowDefinitions>
        <Menu Height="24" Grid.Row="0" Background="#FFEEF5FE">
            <MenuItem Header="File"></MenuItem>
        </Menu>
        <ToolBar Grid.Row="1" Height="40">
            <ToolBar.Background>
                <LinearGradientBrush EndPoint="0,1" StartPoint="0,0">
                    <GradientStop Color="#FFF3F8FF" Offset="0"/>
                    <GradientStop Color="#FFDFECFD" Offset="0.5"/>
                    <GradientStop Color="#FFD1E5FF" Offset="1"/>
                </LinearGradientBrush>
            </ToolBar.Background>
            <Button Width="32" Height="32">
                <Viewbox Stretch="Fill" Width="32" Height="32">
                    <Canvas x:Name="Add_slot" Width="32" Height="32">
                        <Path Stretch="Fill" Width="12.936" Height="5.997" Canvas.Left="0.015" Canvas.Top="0" Data="F1M38.361,430.76C36.907,430.76,35.724,431.949,35.724,433.408L35.724,433.408L35.724,434.111C35.724,435.562,36.893,436.741,38.335,436.754L38.335,436.754L42.316,436.757L46.024,436.757C47.478,436.757,48.66,435.569,48.66,434.111L48.66,434.111L48.66,433.408C48.66,431.949,47.478,430.76,46.024,430.76L46.024,430.76z">
                            <Path.Fill>
                                <LinearGradientBrush EndPoint="0.5,0" StartPoint="0.5,1">
                                    <GradientStop Color="#FF004601" Offset="0"/>
                                    <GradientStop Color="#FF004F01" Offset="0.219788"/>
                                    <GradientStop Color="#FF007201" Offset="1"/>
                            </Path.Fill>
                        </Path>
                        <Path Stretch="Fill" Width="12.508" Height="2.431" Canvas.Left="0.229" Canvas.Top="0.217" Data="F1M38.361,430.977C37.024,430.977,35.94,432.066,35.938,433.408L35.938,433.408L36.366,433.408C36.369,432.305,37.262,431.408,38.361,431.406L38.361,431.406L46.024,431.406C47.123,431.408,48.016,432.305,48.018,433.408L48.018,433.408L48.446,433.408C48.446,432.066,47.361,430.977,46.024,430.977L46.024,430.977z">
                            <Path.Fill>
                                    <GradientStop Color="#FF005E01" Offset="0"/>
                                    <GradientStop Color="#FFACE6AC" Offset="1"/>
                            </Path.Fill>
                        </Path>
                        <Path Stretch="Fill" Width="12.936" Height="5.996" Canvas.Left="3.064" Canvas.Top="4.101" Data="F1M41.409,434.861C39.956,434.861,38.773,436.049,38.773,437.508L38.773,437.508L38.773,438.21C38.773,439.661,39.942,440.84,41.384,440.854L41.384,440.854L45.365,440.857L49.073,440.857C50.526,440.857,51.709,439.669,51.709,438.21L51.709,438.21L51.709,437.508C51.709,436.049,50.526,434.861,49.073,434.861L49.073,434.861z">
                            <Path.Fill>
                                <RadialGradientBrush Center="0.5,0.5" GradientOrigin="0.5,0.5" RadiusX="0.39" RadiusY="0.841">
                                    <GradientStop Color="#FFF6F6F6" Offset="0"/>
                                    <GradientStop Color="#FFE8E8E8" Offset="0.659348"/>
                                    <GradientStop Color="#FFDDDDDD" Offset="1"/>
                                </RadialGradientBrush>
                            </Path.Fill>
                        </Path>
                        <Path Stretch="Fill" Stroke="#FFCECECE" StrokeEndLineCap="Flat" StrokeLineJoin="Miter" StrokeMiterLimit="4" StrokeStartLineCap="Flat" StrokeThickness="0.505" Width="13.441" Height="6.501" Canvas.Left="2.811" Canvas.Top="3.848" Data="M41.3838,440.8545C39.9418,440.8405,38.7728,439.6615,38.7728,438.2105L38.7728,437.5085C38.7728,436.0495,39.9558,434.8605,41.4088,434.8605L49.0728,434.8605C50.5268,434.8605,51.7088,436.0495,51.7088,437.5085L51.7088,438.2105C51.7088,439.6685,50.5268,440.8565,49.0728,440.8565L45.3648,440.8565L41.3838,440.8545z"/>
                        <Path Stretch="Fill" Width="12.508" Height="2.432" Canvas.Left="3.278" Canvas.Top="4.316" Data="F1M41.409,435.076C40.072,435.077,38.988,436.166,38.987,437.508L38.987,437.508L39.415,437.508C39.417,436.405,40.31,435.508,41.409,435.507L41.409,435.507L49.073,435.507C50.172,435.508,51.064,436.405,51.066,437.508L51.066,437.508L51.495,437.508C51.494,436.166,50.409,435.077,49.073,435.076L49.073,435.076z">
                            <Path.Fill>
                                    <GradientStop Color="#FFD4D4D4" Offset="0"/>
                                    <GradientStop Color="#FFFFFFFF" Offset="1"/>
                            </Path.Fill>
                        </Path>
                        <Path Stretch="Fill" Width="5.902" Height="5.9" Canvas.Left="0" Canvas.Top="7.069" Data="F1M35.709,440.779C35.709,442.409,37.03,443.729,38.66,443.729L38.66,443.729C40.289,443.729,41.611,442.409,41.611,440.779L41.611,440.779C41.611,439.149,40.289,437.829,38.66,437.829L38.66,437.829C37.03,437.829,35.709,439.149,35.709,440.779">
                            <Path.Fill>
                                    <GradientStop Color="#FFC86702" Offset="0"/>
                                    <GradientStop Color="#FFED7702" Offset="0.142853"/>
                                    <GradientStop Color="#FFFBBD4B" Offset="1"/>
                            </Path.Fill>
                        </Path>
                        <Path Stretch="Fill" Width="5.227" Height="2.614" Canvas.Left="0.337" Canvas.Top="7.405" Data="F1M36.046,440.779L36.384,440.779C36.387,439.525,37.406,438.505,38.66,438.504L38.66,438.504C39.913,438.505,40.933,439.525,40.935,440.779L40.935,440.779L41.273,440.779C41.272,439.338,40.101,438.166,38.66,438.165L38.66,438.165C37.219,438.166,36.047,439.338,36.046,440.779">
                            <Path.Fill>
                                    <GradientStop Color="#FFF49700" Offset="0"/>
                                    <GradientStop Color="#FFFFF4D3" Offset="1"/>
                            </Path.Fill>
                        </Path>
                        <Path Fill="#FFFFFFFF" Stretch="Fill" Width="3.492" Height="3.491" Canvas.Left="1.205" Canvas.Top="8.273" Data="F1M39.9839,440.356L39.0799,440.358L39.0779,439.453C39.0769,439.221,38.8879,439.033,38.6569,439.033C38.4249,439.033,38.2349,439.223,38.2369,439.455L38.2379,440.359L37.3349,440.362C37.1019,440.362,36.9139,440.551,36.9139,440.783C36.9149,441.015,37.1029,441.203,37.3349,441.202L38.2399,441.2L38.2419,442.106C38.2429,442.338,38.4309,442.525,38.6629,442.524C38.8949,442.524,39.0839,442.336,39.0829,442.104L39.0809,441.198L39.9859,441.196C40.2179,441.196,40.4059,441.008,40.4059,440.776C40.4049,440.543,40.2169,440.356,39.9839,440.356"/>
                    </Canvas>
                </Viewbox>
            </Button>
        </ToolBar>
        <igDock:XamDockManager Margin="0,0,0,0" Name="xamDockManager1" Grid.Row="2" Theme="Aero">
            <igDock:XamDockManager.Panes>
                <igDock:SplitPane igDock:XamDockManager.InitialLocation="DockedLeft" SplitterOrientation="Horizontal">
                    <igDock:ContentPane Name="contentPane1" VerticalAlignment="Top" Header="Locals">
                        <igOutlookBar:XamOutlookBar Height="700" Name="xamOutlookBar1" Width="220" Theme="Office2k7Blue" VerticalSplitterResizeMode="Deferred" AllowMinimized="False">
                            <igOutlookBar:OutlookBarGroup Key="{x:Null}" Header="Group 1">
                                <Grid />
                            </igOutlookBar:OutlookBarGroup>
                            <igOutlookBar:OutlookBarGroup Key="{x:Null}" Header="Group 2">
                                <Grid />
                            <igOutlookBar:OutlookBarGroup Key="{x:Null}" Header="Group 4">
                                <StackPanel>
                                    <my:XamMonthCalendar FontSize="12" Theme="Aero" />
                                </StackPanel>
                        </igOutlookBar:XamOutlookBar>
                    </igDock:ContentPane>
                </igDock:SplitPane>
                <igDock:SplitPane igDock:XamDockManager.InitialLocation="DockedRight" SplitterOrientation="Horizontal">
                    <igDock:ContentPane x:Name="rightEdgeDock1" Header="Calendar" igDock:SplitPane.RelativeSize="100,100" Width="220">
                        <my:XamMonthCalendar FontSize="13" Theme="Aero"  Width="220" AutoAdjustCalendarDimensions="True" CalendarDimensions="1,1" Height="212" VerticalAlignment="Top" Margin="0,10" />
                    <igDock:TabGroupPane igDock:SplitPane.RelativeSize="100,200" Width="220">
                        <igDock:ContentPane x:Name="rightEdgeDock2" Header="Right Edge Dock Pane #1">
                            <!--<locCtls:XdmSamplePaneContent Content="Right Edge Dock Content #1"/>-->
                        <igDock:ContentPane x:Name="rightEdgeDock3" Header="Right Edge Dock Pane #2">
                            <!--<locCtls:XdmSamplePaneContent Content="Right Edge Dock Content #2"/>-->
                        <igDock:ContentPane x:Name="rightEdgeDock4" Header="Right Edge Dock Pane">
                            <!--<locCtls:XdmSamplePaneContent Content="Right Edge Dock Content"/>-->
                    </igDock:TabGroupPane>
                </igDock:SplitPane>
            </igDock:XamDockManager.Panes>
            <igDock:DocumentContentHost>
                <igDock:SplitPane SplitterOrientation="Horizontal">
                    <igDock:TabGroupPane x:Name="tbc" TabStripPlacement="Top">
                        <igDock:ContentPane x:Name="document1" TabHeader="Tab 1">
                            <Test:UserControl1></Test:UserControl1>
                        <igDock:ContentPane x:Name="document2" TabHeader="Tab 2">
                        <igDock:ContentPane x:Name="document3" TabHeader="Tab 3">
                </igDock:SplitPane>
            </igDock:DocumentContentHost>
        </igDock:XamDockManager>
    </Grid>
</Window>
Please help, I've spent ages trying to sort this.
Regards
Alan
