When I export a report and set PageOrientation to Landscape
it export in Portrait orientation
This problem seems to be back in v10.3
Many thanks for letting me know, I'd missed that there was a service release for 2009_2 already :)
after updateing to version 20092_SR_2001
the problem was solved.
I am encountering this exact same problem when trying to export to XPS. Despite setting the page orientation to Landscape, it still saves it in portrait.
I also find that printing works fine, it is just export.
Is there any fix for this.
---- This don't work ---
Private Sub btnExport_Click(ByVal sender As System.Object, ByVal e As
System.Windows.RoutedEventArgs)
Dim saveDlg As SaveFileDialog = New
SaveFileDialog()
saveDlg.Filter =
"XPS documents|*.xps"
If (Not saveDlg.ShowDialog().GetValueOrDefault())
Then
Return
End
If
'// 1. Create Report object
Dim reportObj As Report = New
Report()
'// 2. Create EmbeddedVisualReportSection section.
'// Put the visual you want to print as a parameter of section's constructor
Dim section As EmbeddedVisualReportSection = New
EmbeddedVisualReportSection(Plan)
'// 3. Add created section to report's section collection
reportObj.Sections.Add(section)
reportObj.ReportSettings.PageOrientation = PageOrientation.Landscape
'// 4. Call Export method and put the file name you want to create
reportObj.Export(OutputFormat.XPS, saveDlg.FileName)
Sub
--- This Works ---
Private Sub btnPrint_Click(ByVal sender As System.Object, ByVal e As
reportObj.Print(
True, False
