471
Change the image column when click the contextmenu in wpf grid
Hi all,
     Iam using infragistics  xam  grid.i kept a image of green color with context menu   by giving  static resource  for cell  value presenter in a column in my grid..
if i right click the image  and select any  menu i want to change the color of the image in tat column..
can any one tell me how to do..pls send the code..
  • 69686
    Suggested Answer
    Once you have opened the context menu and clicked on an option from it, you can use our helper methods to get to the element you want:
    Infragistics.Windows.Utilities.GetDescendantFromName(...) and Infragistics.Windows.Utilities.GetDescendantFromType. For parameter "parent element" you should pass in the element you have opened the context menu on - DataRecordPresenter, CellValuePresenter, etc. so that you search the element tree downwards. You can also use Infragistics.Windows.Utilities.GetAncestorFromName and Infragistics.Windows.Utilities.GetAncestorFromType for the other direction.
    Hope this helps
