I have been plauged by a sorting behavior which is becoming very annoying. Each time I perform a group sort on something which has say, 2 items in the group, the first item is hidden. No special cases here, I see this all the time. If I quick sort any column both records appear. Also note, if there is just one record in the sorted group, no records are visible. Image attached.
If you have crossed this bridge, please notify best work around.
Glenn Long
Valley Forge, PA
Alex,
I upgraded to 9.1 this morning which fixed the problem - buggggg.
Also, I just tried to apply the June patch to 9.1 and when starting the install it tells me 9.1 is not installed which aborts the patch setup, huh?
Glenn
I'm am using 8.3 but unfortunately not in a position to go to 9 at the moment. Was this a version thing? Kinda figured it was a bug.
Hello Glenn,
I cannot reproduce this behavior (using latest service release (9.1.20091.2075).
What version of our dlls are you using?
