265
XamComboEditor shows Value rather than Display Text
I'm having a strange issue with using XamComboEditor outside a DataGrid. In my custom user control, I have three XamComboEditors, each has a list of rating objects as its ItemsSource.
The problem is when I bind the control to its initial rating selections, the rating texts are displaying fine in two of the XamComboEditors, but in one of XamComboEditor is displaying the Value rather than the rating text. If I try replacing the XamComboEditors by WPF ComboBoxes then all is showing correctly.
What is more confusing is in the problemetic XamComboEditor, when I select from the dropdown menu, it displays the rating text correctly for some of the items, even after the XamComboEditor lose its focus. But for some items it displays the rating text on selection, and shows the Value instead after the XamComboEditor lose its focus.
Here is my xaml:
<infEditor:XamComboEditor Name="cboLongTerm" Grid.Column="0" Grid.Row="3" Width="58" Height="20" HorizontalAlignment="Center" VerticalAlignment="Center" Margin="2,2,2,2" Foreground="Black" Value="{Binding Path=LongTermRatingID, Mode=TwoWay}"IsEnabled="{Binding Path=IsEnabled}"/>
<infEditor:XamComboEditor Name="cboOutlook" Grid.Column="1" Grid.Row="3" Width="58" Height="20" HorizontalAlignment="Center" VerticalAlignment="Center" Margin="2,2,2,2" Foreground="Black" Value="{Binding Path=OutlookRatingID, Mode=TwoWay}" IsEnabled="{Binding Path=IsEnabled}"/>
<infEditor:XamComboEditor Name="cboShortTerm" Grid.Column="2" Grid.Row="3" Width="58" Height="20" HorizontalAlignment="Center" VerticalAlignment="Center" Margin="2,2,2,2" Foreground="Black" Value="{Binding Path=ShortTermRatingID, Mode=TwoWay}" IsEnabled="{Binding Path=IsEnabled}"/>
 and I'm setting the ItemSource in code:
public
void PopulateRatings(List<RatingAgencyRating> ltratings,List<RatingAgencyRating> stratings,List<RatingOutlook> outlooks) {
cboLongTerm.ItemsSource = ltratings;
cboLongTerm.DisplayMemberPath =
"Rating";
cboLongTerm.ValuePath =
"AgencyRatingID";
cboShortTerm.ItemsSource = stratings;
cboShortTerm.DisplayMemberPath =
"Rating";
cboShortTerm.ValuePath =
"AgencyRatingID";
cboOutlook.ItemsSource = outlooks;
cboOutlook.DisplayMemberPath =
"Name";
cboOutlook.ValuePath =
"Id";
Has anyone had a similar problem before?
Tess
