Is it possible to display the legend items horizontally ? For example if I decide to show the legend at the bottom of the chart, I would like the legend items to display as one line left to right instead of stacked.
Thanks in advance,
sorry, only vertical stacking of legend items is supported in the current version. you can submit a feature request here: http://devcenter.infragistics.com/protected/requestfeature.aspx
Currently there is no build-in functionality to display the legend items horizontally. However I think this could be possible by creating a custom LegendItemTemplate and set some transformations (RotateTransform,TranslateTransform) to the elements or rotating the whole Legend. Also you can iterate throug the VisualTree and get the ContentControls which are used to present the legent items and then set a margin or transformation to them. You can refer to the following threads in the forums about how to change the position of the Legend and how to create custom template for the items:
http://blogs.infragistics.com/forums/p/16513/61491.aspx
http://blogs.infragistics.com/forums/p/16513/60140.aspx
In order to get this feature into a future release,please submit a feature requst at the following webpage:
http://devcenter.infragistics.com/Protected/RequestFeature.aspx
Hope this helps
Regards
Vlad
