1155
Changing the Display count on Sorted Items
Question: I want to modify the record count display for grouped/sorted items
I have a button which groups and expands a certain item based on the Description - ok easy enough.
Now, I am checking each row displayed to see if it has a certain value in a column, say > 0. If not I collapse the visible row. At the same time I want to reduce by 1 the number of records shown as ChildRecords of the group. Is it possible to modify that count.
Bottom line: If a record doesn't meet a criteria, it doesn't get displayed. Also I don't want the user thinking there are more records in the group than which are actually displayed.
Clear? Below is where I sort out the records. All works well here. Obviously I can't set the readOnly Count property, but in pseudo code that's what I want to accomplish.
Glenn Long
  void AreaUnitDetails_RecordsInViewChanged(object sender, Infragistics.Windows.DataPresenter.Events.RecordsInViewChangedEventArgs e)
            Infragistics.Windows.DataPresenter.Record[] gbr;
            gbr = this.AreaUnitDetails.GetRecordsInView(false);
            foreach (Infragistics.Windows.DataPresenter.Record rec in gbr)
                if (!rec.IsExpanded && rec.Description.StartsWith("CT"))
                    rec.IsExpanded = true;
                    var children = rec.ViewableChildRecords.ToList();
                    foreach (Record child in children)
                        if (((ASEngine.BusinessObjects.Entities.UnitDetail)(((Infragistics.Windows.DataPresenter.DataRecord)(child)).Cells.Record.DataItem)).RegMW.Value == 0)
                            child.Visibility = Visibility.Visible;
                        //rec.ViewableChildRecords.Count = rec.ViewableChildRecords.Count;  // Decrement count Displayed by 1.
Picture: As you can see the group CT has 4 records by count but none displayed as I have filtered them out. I want that count to show 0 or whatever is left in the list.
