315
IndexOutOfRangeException on ApplyTemplate() when XamDataGrid has its theme set
I've run into an issue that I can seem to track down. I've attached a sample solution that reproduces the issue.
I'm binding a ContentControl's content to a workspace object that can change to different workspaces. I'm also creating a DataTemplate for each type of workspace so WPF knows how to render the workspace. The issue I'm running into, is when I attempt to inspect the VIsualTree of the current workspace and that workspace contains a XamDataGrid with its theme set. To inspect the VIsual Tree, I'm calling ApplyTemplate(). If one of the workspace views contains a XamDataGrid, and the XamDataGrid's Theme property is set, I start running into trouble. If I remove the Theme setting on the XamDataGrid, it works fine.
I don't beleive I'm doing anything wrong and since the only way to induce the problem (that I've seen so far) is to set a Theme on a XamGrid.
Can someone double check my sample and see if I'm doing anything wrong? Thanks!
GridThemeIssue.zip
