I have a grid where there items must be sorted by a hidden field !
I have try this :
<igDP:FieldLayout.SortedFields> <igDP:FieldSortDescription FieldName="Priority"/> </igDP:FieldLayout.SortedFields>
<igDP:Field Name="Priority" Label="Priority" Visibility="Collapsed"> <igDP:Field.Settings> <igDP:FieldSettings CellClickAction="SelectRecord" AllowEdit="False" LabelWidth="300" CellWidth="300"/> </igDP:Field.Settings> </igDP:Field> <igDP:Field Name="Title" Label="Title"> <igDP:Field.Settings> <igDP:FieldSettings CellClickAction="SelectRecord" AllowEdit="False" LabelWidth="300" CellWidth="300"/> </igDP:Field.Settings> </igDP:Field>
But the list is not sorted by priority! I must set the default sort field ?
http://ko.infragistics.com/gethelp (scroll down to 'Request Developer Support Online')
Joe Modica
Also, when a "property" of a DataItem is updated, the "sort order" is not refreshed .
I can change dynamically the "priority" field value, but its position remain the same.
Even when I add a new item in the list... it is added at the end !
