896
Programmatically applying style to the CellValuePresenter
Hi
I have this Style
<Style x:Key="HighlightCells" TargetType="{x:Type igDP:CellValuePresenter}">
<Setter Property="Background" Value="Red" /></Style>
I am applying it like this
e.Cell.Field.Settings.CellValuePresenterStyle = TryCast(FindResource("HighlightCells"), Style)
in
EditModeEnded event handler
But the style is not getting applied, this is not the case if i apply the same style as a static resource
  • 69686
    Suggested Answer
    This is because the CellValuePresenter has to be reinitialized before the style can be applied. For example, if you group and ungroup the style would apply or the cell is scrolled out of view and then back into view.
    You should set the CellValuePresenter's properties directly  or reinitialize the XamDataGrid.
