1405
XamDateTimeEditor focus problem
Hy all.
I have a question about the XamDateTimeEditor control.
I have a simple wpf application with a form for which I set the DataContext to a Controller class.
In this Controller class I have an object that has two properties. The DateTime property (DateValue) it's bounded to the XamDateTimeEditor value and the string property (TextValue) it's bounded to a TextBox control.
I have noticed that every time when the XamDateTimeEditor gets the focus, it will call the set method for the DateValue of the object even if the DateValue was not changed. For the TextBox control it will call the set method of the TextValue property only after losing the focus on the control.
Do you know if I must do something so that the XamDateTimeEditor will not call the set method when it gets the focus? I have also attached a sample.
Thanks a lot.
Nico
WpfXamDateTimeTest.zip
