Hi
Is there some way to bind the field.Visibility property to the data in my business object?
Thanks Alex.
The blog does explain alot but I have another question.
Can I do the same binding as described in the blog, but in the code-behind?
I could not find the SetBinding method on Field.
I need to set the binding in code-behind since I dynamicaly configure the fields layout in fieldlayoutinitializing event.
Thanks.
You can find more information on how to do this in this blog post by Josh Smith:
http://blogs.infragistics.com/blogs/josh_smith/archive/2008/06/06/binding-a-xamdatagrid-field-property.aspx
Hope this helps.
