Is it possible to hide column headers? Using a drill-down grid as a 'selection list' that displays a single column would be cleaner without the header.
Hello Alexander,
Thank you for your post. I have been looking into it and I can suggest you check these forum threads:
http://ko.infragistics.com/community/forums/p/62567/316956.aspx
http://ko.infragistics.com/community/forums/p/53090/276218.aspx
http://ko.infragistics.com/community/forums/p/59135/407997.aspx
where there are different approaches fro synchronizing the headers. Please let me know if this helps you or you need further assistance on this matter.
In my application I have master table with nested table elements (2 layers) in a xamDataGrid. I wanted to have the header for the nested table elements suppressed. The proposed solution worked fine so far.
But to align the cell width of master table and nested table, I tried to handle the SizeChanged events for the columns additionally. To do so, I added a style for the target type "LabelPresenter". As long as your FieldLayoutSetting is contained in my xaml the event handler is never called (when changing the column width of a corresponding table row). It seems that the style becomes disabled by a local field setting.
Do you have a solution which combines both:
1) disable the header
2) allow handling of the SizeChanged events
Thanks in advance!
This is a very nice solution. More on this issue, is there a way that I can show/hide column headers individually?
I have a Approve/Reject button column in the second row for every data record. I do not want to show header for this column. Sample code is attached.
<igDP:XamDataGrid.FieldLayouts>
<igDP:FieldLayout>
<igDP:FieldLayout.Fields>
<igDP:Field Label="Draw Date" Name="DrawDate" Row="0" Column="0" />
<igDP:Field Label="Deal Name" Name="DealName" Row="0" Column="1" />
<igDP:Field Label="Draw Amount" Name="DrawAmount" Row="0" Column="2" />
<igDP:Field Label="Draw Number-SubIndex" Name="DrawNumberSubIndex" Row="0" Column="3" />
<igDP:Field Label="Request Received Date" Name="RequestReceivedDate" Row="0" Column="4" />
<igDP:Field Label="Approval Pending From" Name="ApprovalPendingDate" Row="0" Column="5" />
<igDP:Field Label="Title Required" Name="TitleRequired" Row="0" Column="6" />
<igDP:Field Label="DrawDown" Name="DrawDown" Row="0" Column="7" />
<igDP:Field Label="Capitalized Interest" Name="CapitalizedInterest" Row="0" Column="8" />
<igDP:UnboundField Row="1" Column="0" ColumnSpan="9" Label="{x:Null}">
<igDP:Field.Settings>
<igDP:FieldSettings
CellValuePresenterStyle="{StaticResource ApproveRejectButtons}"
AllowRecordFiltering="False"
AllowGroupBy="False"
AllowSummaries="False"
</igDP:Field.Settings>
</igDP:UnboundField>
</igDP:FieldLayout.Fields>
</igDP:FieldLayout>
</igDP:XamDataGrid.FieldLayouts>
Subu
Sweet. That worked perfectly.
Thank you.
<igDP:XamDataGrid>
<igDP:XamDataGrid.FieldLayoutSettings> <igDP:FieldLayoutSettings LabelLocation="Hidden"/> </igDP:XamDataGrid.FieldLayoutSettings>
</igDP:XamDataGrid>
