315
IDataErrorInfo Support in UnboundField
I see the new support for IDataErrorInfo when I use a Field object, but when I use the UnboundField object, I don't see any validation happening. The following works:
<data:Field Name="CoverageAmount" Label="Coverage" Settings="{StaticResource CurrencyFieldSettings}" />
However, the following DOES NOT work:
<data:UnboundField BindingPath="Coverage.BaseAmount" Label="Base Coverage" Settings="{StaticResource CurrencyFieldSettings}" />
I need to use UnboundField in some cases because the property being modified is a property of an object that is only reached form a property of my record's data source.
How can I have the same support for IDataErrorInfo in UnboundField as I get with Field?
