hi is it possible to bind each column to a different data source. basically were are building a trading app, we got vectors with represent live rates etc.. there are a number of these and need to be bound to a column. is this possible in xamgrid
isaiahperumalla said: Thanks is there any other controls where this might be possible ?
It shouldn't be that difficult to create some sort of facade or view model class that would consolidate your multiplicity of data sources into a single one; then use this to bind to the grid.
To the best of my knowledge, this is not possible. The XamDataGrid only exposes the DataItems property, which is IEnumerable. This allows only one data source to be bound to the grid at a time.
You could achieve this, but merging the different data sources into one and then binding to the XamDataGrid.
