605
Hidding Button in AddNew-Row
I have created an UnboundField with a ControlTamplate and a button in it.
This Button is used to delete a Row. I would like to hide this button in the AddNew-Row because it doesn't make sence to delete a not existing Row.
Do you have an Idea how to solve this Problem?
Here is the Code of the Column:
<igDP:UnboundField Name="">
<igDP:UnboundField.Settings>
<igDP:FieldSettings CellClickAction="Default" AllowEdit="False" AllowGroupBy="False">
<igDP:FieldSettings.CellValuePresenterStyle>
<Style TargetType="{x:Type igDP:CellValuePresenter}">
<Setter Property="Template">
<Setter.Value>
<ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}">
<Button Click="dg_belege_delete_click">x</Button>
</ControlTemplate>
</Setter.Value>
</Setter>
</Style>
</igDP:FieldSettings.CellValuePresenterStyle>
</igDP:FieldSettings>
</igDP:UnboundField.Settings>
</igDP:UnboundField>
Yourse sincerealy
Thomas
  • 69686
    Verified Answer
    Hello Thomas,
    You can do this by creating a Trigger/DataTrigger and check for the IsAddRecord property of the DataRecordPresenter and if it is true, hide the button. You can use something like this:
                            <ControlTemplate.Triggers>
                                <DataTrigger Binding="{Binding Path=IsAddRecord}" Value="True">
                                    <Setter Property="Visibility" TargetName="delImage" Value="Collapsed"/>
                                </DataTrigger>
                            </ControlTemplate.Triggers>
    where your target name would be the name of the button.
    Hope this helps.
