I am using the 9.2.20092.2001 hot fix of the 9.2 libraries and am having a hard time getting IDataErrorInfo support to work correctly. I have a class called Data that implements INotifyPropertyChanged and IDataErrorInfo. My IDataErrorInfo properties both have a Console.WriteLine in there to let me know when they are being called.When the data is first bound to the grid, the Error property is called multiple times. However, the this[string columnName] property is never called. Whenever I update a property, nothing happens. Should I be notifying when my Error property changes? Is there a sample somewhere on how to properly implement IDataErrorInfo so that the XamDataGrid supports it.
Edit: I am setting the properties: DataGrid.FieldLayoutSettings.DataErrorDisplayMode = DataErrorDisplayMode.Default; DataGrid.FieldLayoutSettings.SupportDataErrorInfo = SupportDataErrorInfo.RecordsAndCells;
Thanks,-Szymon
The issue with the Unbound fields is already fixed and will be included in the next service release. More details about the service release dates can be found here:http://ko.infragistics.com/support/default.aspx#ServiceReleases
I hope this helps.
Sincerely,DimiDeveloper Support EngineerInfragistics, Inc.
I'm looking for a fix for this too. Any updates?
i would like to bump this
Are you still working on a fix for Idataerrorinfo on unbound fields? Can we expect a solution in the near future?
Regards
Stef
It seems to be a know bug that IDataErrorInfo does not support in an UnboundField properly. Have you already released a fix on this? Or do you have a schedule when it shall be fixed?
Thanks!
Edward
hi i have the same issue
idataerrorinfo with unbound fields and complex structures is an important feature for me.
A Quick fix for this bug would be appreciated
regards
stef
