325
Select Parent and change style property
I have a datagrid view setup to mimic a treeview.
When a user selects a deeply nested 'node' and clicks a button on the form I need it to select only it's parent nodes and their parent's nodes then make them bold.
I have:
        private void MarkAsAdded(object p)
            try
                DataRecord addedRecord = (DataRecord)p;
                DataRecordPresenter drp = (DataRecordPresenter)DataRecordPresenter.FromRecord(addedRecord) as DataRecordPresenter;
                addedRecord.Cells["IsAdded"].Value = "True";
                drp.FontWeight = FontWeights.Bold;
                if (addedRecord.Cells["IsFolder"].Value.ToString() == "True")
                    if (addedRecord.ChildRecords.Count > 0)
                        addedRecord.Cells["HasAddedChildren"].Value = "True";
                        drp.FontStyle = FontStyles.Italic;
                if (addedRecord.ParentRecord != null)
                    bool done = false;
                    DataRecord dr = (DataRecord)addedRecord.ParentDataRecord;
                    do
                        if (dr != null)
                            DataRecordPresenter tdrp = DataRecordPresenter.FromRecord(dr) as DataRecordPresenter;
                            dr.Cells["HasAddedChildren"].Value = "True";
                            tdrp.FontStyle = FontStyles.Italic;
                            dr = (DataRecord)dr.ParentDataRecord;
                        else
                            done = true;
                    } while (done == false);
            catch (Exception ex)
So far, but it is buggy.
and selects the parent... and it's children. then bolds them.
Is there a solution to this?
Matt.
  • 69686
    Verified Answer
    Hello Matt,
    This looks quite complex to me of achieving this goal. Here is one recursive method of doing this:
    1. When you select a record, set its FontWeight to Bold. You can do that by handling the RecordActivated Event of the XamDataGrid and call the following method:
    HightLightExpanded(e.Record as DataRecord); where:
    private void HightLightExpanded(DataRecord dataRecord)
                DataRecord dr = dataRecord;
                if (dr == null)
                    return;
                dr.Tag = "Bold";
                HightlightParents(dr);
    2. The HightlightParents method recursively gets the parents and highlights them as well
    private void HightlightParents(DataRecord dataRecord)
                DataRecord parent = dataRecord.ParentDataRecord;
                if (parent == null)
                    return;
                else
                    parent.Tag = "Bold";
                    if(parent.ParentDataRecord!=null)
                    HightlightParents(parent.ParentDataRecord);
    3. Here is the style for the DataRecordPresenter which actually high lights the records:
    <Style TargetType="{x:Type igDP:DataRecordPresenter}">
            <Setter Property="FontWeight" Value="{Binding Path=Tag}"/>
        </Style>
    As you can see, I am using a style that binds the Tag to the FontWeight. The reason I am doing this is because I want to avoid getting the DataRecordPresenter (makes the code more unreadable) in c#.
    4. Reset the FontWeight when you change the selection. You can do this either before a new selection or in the RecordDeactivating event. You can again use similar recursive function to reset the Tag the same way you set it.
    Hope this helps.
