Can anyone tell me why it takes up to 2 sec. to expand one node of this hierarchical grid (attached sample)?
We have quite fast machines and we expect better performance from the xamdatagrid.
(Core 2 Quad with 4GB of RAM).
Thanks.
PS. Tried with version 9.1.2091 and 9.2.2001. Both have the problem.
HI,
I will bring this issue to the attention of our developers Sincerely,
Matt Developer Support Engineer
I don't see any difference too...
Hi Matt,
I tried the 2010.3 today and updated the sample application to use the new version. However, the expansion performance is still the same, I couldn't tell the difference between this and running it with 2010.2. Please raise the issue to development team and we still need further help on this issue... . Thanks, Yu
That is good news that you are improving the performance of the grid
Because the performance of the xamdatagrid is very bad at the moment.
In my usage of the grid the standard wpf datagrid takes less than a second to refresh with a new set of data ( 30 rows, 9 columns 4 columns with combo boxes)
and the xamdatagrid takes 5-6 seconds to do the same refresh with the same data and setup. Excluding the custom colouring of cells that occurs on the wpf grid. 5-6 seconds is almost unusable.
I look forward to the new release with speed improvements
Regards
Murray
Our NetAdvantage 10.3 release will be addressing performance.
Here a help link to the roadmap
http://ko.infragistics.com/innovations/roadmap/wpf.aspx#WPF Here a help link to Peformance Optimizations Overview for the XamDataGrid http://help.infragistics.com/NetAdvantage/WPF/2010.2/CLR4.0/
Sincerely, MattDeveloper Support Engineer
