495
Empty rows
I have a custom framework with a base ClientEntity object.
When I supply a xamDataGrid with a datasource of List of 10 ClientEntity objects , there are just 10 blank rows with as much columns as I defined (if autogeneratecolumns = true, just a lot of blanks columns).
The code works with a different object (just some random test object) - so the problem is probably in the ClientEntity, which implements a lot of PropertyDescriptor logic and such.
What could be the problem here? how does XamDataGrid attempt to fill it's cell values?
In runtime, the DataItem for each DataRecord is correct and contains the real entity, but the Cell.Value is always null.
Thank you.
