I just ran into a problem I (or a tester) should have noticed a long time ago.
Let's say I have a usercontrol which contains a dock manager, which contains a number of panes, each with a different usercontrol.
The user controls in the panes are "dumb" - the main usercontrol (the one that owns the dock manager) has routed command bindings, and supplies data for the controls to display. If, for example, the user clicks on a row in a XamDataGrid in a control, it executes a routed command that is defined in the main control. The main control does whatever has to be done, and updates the datacontext of the various panes.
This works as long as all the panes are docked. However, I just noticed that if I undock a pane that hosts a usercontrol that uses a routed command and leave the pane floating, then the routed command never gets executed. This actually makes sense (I think): When a pane is floating, it's no longer part of the element tree of the main usercontrol like it was while docked (I sort of confirmed that with Snoop.)
Any suggestions as to how to handle this kind of interaction without using routed commands? I'm kind of scr***d here!
Thanks,Michel
If Pinned state of ContentPane changes I experienced that loaded event of all controls in it (UserControl and its child control) gets fired. This thing resets the settings I applied in the loaded event of Usercontrol and its child control.
Why Loaded event of each contol in ContentPane gets fired on Pinned State change..?
If this is a bug then in which version it is resolved..? I am using v9.2 (9.2.20092.2094).
Thanks Andrew
Works great!
Hello Michel,
I have created a support ticket on your behalf regarding this issue with number CAS-44566-8NFN0P so I can link it to the development issue Andrew had created for you.
Sincerely,
Petar Monov
Developer Support Engineer
Infragistics Bulgaria
www.infragistics.com/support
Hi Andrew,
Yeah I had no idea what to do with that ToolWindow the last time (the online help is of little help), so I just went on to more pressing matters. I just tried the code you posted and this seems to work perfectly. Thanks a lot!!
Michel
So just to be clear, you have commands associated with commandsource elements (e.g. a Button with the Command set to some routed command). Once the pane is floating the ancestor of the xamDockManager which was handling (either via events or commandbindings) the CanExecute/Execute for those commands is no longer getting those calls for the floating panes. If that's the case then you can work around this by handling the ToolWindowLoaded as I mentioned originally. Then you can either add CommandBindings to the ToolWindow or better still handle the CanExecute/Execute generically and reraise them on the dockmanager. In thinking about this it seems like the xamDockManager should do this itself so I'm going to write up an issue for this but in the interim you can do something like the following to delegate the CanExecute/Execute.
private static void OnToolWindowCanExecuteCommand(object sender, CanExecuteRoutedEventArgs e){ PaneToolWindow tw = sender as PaneToolWindow; XamDockManager dm = XamDockManager.GetDockManager(tw); if (dm != null) { RoutedCommand rc = e.Command as RoutedCommand; if (null != rc) { // if the CanExecute reaches the ToolWindow then nothing has // handled it. we'll delegate the canexecute call to the dockmanager // and let it bubble up from there e.CanExecute = rc.CanExecute(e.Parameter, dm); e.ContinueRouting = false; e.Handled = true; } }} private static void OnToolWindowExecuteCommand(object sender, ExecutedRoutedEventArgs e){ PaneToolWindow tw = sender as PaneToolWindow; XamDockManager dm = XamDockManager.GetDockManager(tw); if (dm != null) { RoutedCommand rc = e.Command as RoutedCommand; if (null != rc) { // if the Execute reaches the ToolWindow then nothing has // handled it. we'll delegate the canexecute call to the dockmanager // and let it bubble up from there rc.Execute(e.Parameter, dm); e.Handled = true; } }} private void OnToolWindowLoaded(object sender, PaneToolWindowEventArgs e){ e.Window.AddHandler(CommandManager.CanExecuteEvent, new CanExecuteRoutedEventHandler(OnToolWindowCanExecuteCommand)); e.Window.AddHandler(CommandManager.ExecutedEvent, new ExecutedRoutedEventHandler(OnToolWindowExecuteCommand));}
