If I set the DataRecord to Collasped in a InitializeRecordEvent handler I will get intermittent hidden records and UnhandledExceptions at the application level when scrolling the window. Has anyone seen this?
I am using 9.1.
/*****************Handler**************/
private void PlanGridRecordInit(object sender, InitializeRecordEventArgs e) { DataRecord rec = e.Record as DataRecord; Infragistics.Windows.DataPresenter.CellCollection cells = rec.Cells; double RelNo = double.Parse(cells["RelNo"].Value.ToString()); if (currentRelease != 0&& RelNo != currentRelease) rec.Visibility = Visibility.Collapsed; else rec.Visibility = Visibility.Visible; }
/******************XAML*********************************/
<igDP:XamDataGrid Grid.Row="3" Drop="PlanListDrop" PreviewKeyUp="PlanListXFind" Name="PlanListX" EditModeEnded="PlanChanged" SelectedItemsChanged="PlanListXSelectionChanged" Theme="Aero" AllowDrop="True" Background="LightGoldenrodYellow" RecordsDeleted="DeletedRecord" RecordsDeleting="DeletingRecord" GroupByAreaLocation="None" FontSize="9" InitializeRecord="PlanGridRecordInit" Loaded="PlanXLoaded"> <igDP:XamDataGrid.FieldSettings> <igDP:FieldSettings CellHeight="19" LabelHeight="18" LabelClickAction="Nothing"/> </igDP:XamDataGrid.FieldSettings> <igDP:XamDataGrid.Resources> <Style TargetType="{x:Type igDP:DataRecordCellArea}"> <Setter Property="BackgroundActive"> <Setter.Value> <LinearGradientBrush EndPoint="0,1" StartPoint="0,0"> <GradientStop Color="LightSalmon" Offset="0"/> <GradientStop Color="White" Offset="1"/> </LinearGradientBrush> </Setter.Value> </Setter> <Setter Property="BorderActiveBrush" Value="#FF000000"/> <Style.Triggers> <DataTrigger Binding="{Binding RelativeSource={RelativeSource Self}, Path=Record.DataItem.Operation}" Value="{x:Null}"> <Setter Property="Background" Value="LightSteelBlue" /> </DataTrigger> <DataTrigger Binding="{Binding RelativeSource={RelativeSource Self}, Path=Record.DataItem.Operation}" Value="100"> <Setter Property="Background" Value="LightSteelBlue" /> </DataTrigger> <DataTrigger Binding="{Binding RelativeSource={RelativeSource Self}, Path=Record.DataItem.InUse}" Value="True"> <Setter Property="Background" Value="Red" /> <Setter Property="Foreground" Value="White" /> </DataTrigger> <DataTrigger Binding="{Binding RelativeSource={RelativeSource Self}, Path=Record.DataItem.Status}" Value="D"> <Setter Property="Background" Value="Black" /> <Setter Property="Foreground" Value="White" /> </DataTrigger> </Style.Triggers> </Style> <Style TargetType="{x:Type igEditors:XamNumericEditor}" BasedOn="{StaticResource XamNumericEditor}" > <Setter Property="HorizontalContentAlignment" Value="Left" /> </Style> <ContextMenu x:Key="RecordContextMenu"> <MenuItem Header="Request Preq" Click="RequestPreqClick" /> <MenuItem Header="Copy OD and Wall Down" Click="CopyODWallDown" /> <MenuItem Header="Clear OD and Wall Down" Click="ClearODWallDown" /> <MenuItem Header="Copy QtyPln and QtyU Down" Click="CopyPlnDown" /> <MenuItem Header="Clear QtyPln and QtyU Down" Click="ClearPlnDown" /> <MenuItem Header="Copy Length Down" Click="CopyLengthDown" /> <MenuItem Header="Clear Length Down" Click="ClearLengthDown" /> <MenuItem Header="Create New Product" Click="newProduct_Click" /> <MenuItem Header="Compare Product Revs" Click="ProductCompare_Click" /> </ContextMenu> <ContextMenu x:Key="OrdNumMenu"> <MenuItem Header="Show Schedule" Click="ShowSchedClick" /> </ContextMenu> <Style TargetType="{x:Type igDP:CellValuePresenter}"> <Setter Property="ContextMenu" Value="{StaticResource RecordContextMenu}" /> <Setter Property="BackgroundSelected" Value="LightGray"/> </Style> </igDP:XamDataGrid.Resources> <igDP:XamDataGrid.FieldLayoutSettings> <igDP:FieldLayoutSettings AllowAddNew="False" AddNewRecordLocation="OnBottom" HighlightAlternateRecords="True" /> </igDP:XamDataGrid.FieldLayoutSettings> </igDP:XamDataGrid>
Thanks for the reply. I finally got back to this issue, it does to be fixed by the hotfix.
I haven't seen that issue. Have you tried testing this with the latest hotfix? Also would it be possible to post the callstack of the exception you are seeing?
