Hi all
Iam Using Xam Ribbon Control ,when i Double click the any tabs in ribbon The ribbon Isminimisable gets True if it false and it gets false when it is true...how to prevent tat.?
can any one help to Fix the problem...
No there is no supported means of avoiding this as doing so would be a violation of your license agreement with Microsoft which allows you to use the Ribbon UI in your application.
Hi
Thank u for ur reply..But i want tat allow minimise property to be true ..how to prevent tat allow minimise change when i double click betwen tabs..Any idea
Thank u
The MS Office UI guidelines dictate that if the ribbon is allowed to be minimized then double clicking a tab must toggle the minimized state. If you do not want to support minimizing the ribbon you may set the AllowMinimize property to false.
