604
XamCarouselListBox - selected item always in the center
Hi
I would like to make sure that the selected item is alsways in the middle.
To achieve this in the CarouselSelectionChanged event handler I used the
XamCarouselPanelCommands
.NavigateToNextItem and
.NavigateToPreviousItem commands.
The problem:
In the carousel loaded event handler I make the first item (indexed 0) selected.
carousel.SelectedIndex = 0;
Then I scroll the carousel to previous item 4 times (since I have 9 items per page, and I basicaly need to bring the selected item 0 to center). I do the following:
for (int i = 0; i < 4; i++)
{panel.ExecuteCommand(
XamCarouselPanelCommands.NavigateToPreviousItem);}
But those lines make no effect. The selected index 0 is still at the left side of the carousel.
How can I make this work?
Thank you
  • 69686
    Suggested Answer
    If you need to scroll the items when they are loaded, you have to turn off the transition animation
    You can do that like this:
    xamCarouselListBox1.ViewSettings.ShouldScrollItemsIntoInitialPosition = false;
    Let me know if that is what you are looking for.
