Hi, I've got an issue with the XamDataGrid that occurs when I have an empty list and also have the AddRow located at the bottom. I've attached a sample that reproduces the issue. For now, I've just put the AddRow at the top.
Mike
If you think that this is the same issue as you have, you can open a support request here and request that your case should be linked to 24611. Please also reference this forum thread.
We have a similar problem. Our application freezes if we set the AddNewRecordLocation Property to OnBottom.
The Grids DataSource is set to a BindingListCollectionView. I can't provide a sample.
When isolating the problem, it seems that this issue is reproducible only when the AddNewRecordLocation is OnBottom or OnTop. If this is set to OnBottomFixed or OnTopFixed it works correctly.
Joe,
I have created cases for both of you. I am going to investigate what is causing this. If there is any way around this I will post it here in the forum, otherwise you will be notified when the service release for this issue is out.
Alex,
Could you please cc me on the support issue - my app (on 9.2) is facing it too and I'd be interested to know the resolution. That or, if you could post the resolution / its availability on this forum
Joe
