I was just wondering if there is any reason the IsFocusWithin property is just a boolean property and not a DependencyProperty?
I would like to use it in a style trigger, which currectly does not work. I'm using IsKeyboardFocusWithin instead, which is sort of ok, but would prefer to detect logical focus.
Any chance this can be changed in a future release?
Dave
Hi Andrew,
I actually created a support case (CAS-34973-DOUX03) this morning, that's currently awaiting assignment.
Thanks for the info, hopefully it won't be too difficult to expose that DP for us then :-)
Cheers,
It actually is backed by a DP but the DP is not exposed which I think is what is leading to the problem. I'll see about getting a case created for you for this issue.
