488
Edit mode
Is there a way to disable a particular column so it can't be edited. Also, how do I prevent a cell entering edit mode when a cell is selected with the mouse but still allow it to enter edit mode when F2 is pressed.
  • 69686
    Suggested Answer
    You can use the EditModeStarting event and cancel it if the F2 key is not pressed, like so:
     void xamDataGrid1_EditModeStarting(object sender, Infragistics.Windows.DataPresenter.Events.EditModeStartingEventArgs e)
                if (!Keyboard.IsKeyDown(Key.F2))
                    e.Cancel = true;
    As you need this for a specific field, you can check the e.Cell.Field property as well.
