325
Bind to current DataContext
Hi!
I created a class that represents a model and contains a property "TimeSeries". An instance of that class is set as DataContext of my view that implements a xamChart. Unfortunately the timeseries are not displayed. Following you will find the piece of xaml code that defines the chart:
 <my:XamChart Name="ChartTimeseries" Grid.Row="1" Grid.Column="1" Width="Auto" Height="Auto" Margin="25" >
            <my:XamChart.Series>
                <my:Series
                      StrokeThickness="4"
                      ChartType="Line"
                      DataSource="{Binding TimeSeries, UpdateSourceTrigger=PropertyChanged}"
                      DataMapping="ValueX=ValueAsOf; ValueY=ValueAbsolute"
                      Fill="#FF6CA224" >
                </my:Series>
            </my:XamChart.Series>
            <my:XamChart.Axes>
                <my:Axis AxisType="PrimaryX" >
                    <my:Axis.Label>
                        <my:Label Format="{}{0}" />
                    </my:Axis.Label>
                </my:Axis>
                <my:Axis AxisType="PrimaryY">
                    <my:Axis.Label>
                        <my:Label Angle="-45" Format="{}{0:c}" />
                    </my:Axis.Label>
                </my:Axis>
            </my:XamChart.Axes>
</my:XamChart>
Please could you help me?
Regards
Dan
  • 30692
    Suggested Answer
    If you are using a line chart, then the DataMapping doesn’t use ValueX and ValueY chart parameters, but rather Label for the X axis, and Value for the Y axis, because it’s treated as a “Single value chart”. So adjusting the Xaml to look like so should work:
    <Window x:Class="WpfApplication3.Window1"
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        Title="Window1" Height="300" Width="300"
            xmlns:my="http://infragistics.com/Chart">
        <Grid>
                    <my:Series
                          StrokeThickness="4"
                          ChartType="Line"
                          DataMapping="Label=ValueAsOf; Value=ValueAbsolute"
                          Fill="#FF6CA224" >
                    </my:Series>
                <my:XamChart.Axes>
                        <my:Axis.Label>
                        </my:Axis.Label>
                    </my:Axis>
                        <my:Axis.Label>
                        </my:Axis.Label>
                    </my:Axis>
                </my:XamChart.Axes>
            </my:XamChart>
        </Grid>
    </Window>
    And this is the code behind I used:
    public partial class Window1 : Window
            public Window1()
                InitializeComponent();
                this.DataContext = new TimeSeriesViewModel();
        public class TimeSeriesViewModel
            private ObservableCollection<TimeEntryViewModel> _timeSeries;
            public ObservableCollection<TimeEntryViewModel> TimeSeries
                get
                    if (_timeSeries == null)
                        _timeSeries = TestDataProvider.GetData();
                    return _timeSeries;
        public class TimeEntryViewModel
            public DateTime ValueAsOf { get; set; }
            public double ValueAbsolute { get; set; }
        public class TestDataProvider
            public static ObservableCollection<TimeEntryViewModel> GetData()
                ObservableCollection<TimeEntryViewModel> list = new ObservableCollection<TimeEntryViewModel>();
                list.Add(new TimeEntryViewModel() { ValueAsOf = new DateTime(2009, 1, 1), ValueAbsolute = 11 });
                list.Add(new TimeEntryViewModel() { ValueAsOf = new DateTime(2009, 2, 1), ValueAbsolute = 10 });
                list.Add(new TimeEntryViewModel() { ValueAsOf = new DateTime(2009, 3, 1), ValueAbsolute = 10 });
                list.Add(new TimeEntryViewModel() { ValueAsOf = new DateTime(2009, 4, 1), ValueAbsolute = 9 });
                list.Add(new TimeEntryViewModel() { ValueAsOf = new DateTime(2009, 5, 1), ValueAbsolute = 11 });
                list.Add(new TimeEntryViewModel() { ValueAsOf = new DateTime(2009, 6, 1), ValueAbsolute = 10 });
                list.Add(new TimeEntryViewModel() { ValueAsOf = new DateTime(2009, 7, 1), ValueAbsolute = 12 });
                return list;
