695
Convert XAML style to code
I have a style in XAML which works fine but now I have to create this style in the code behind. My problem is with setting the binding to the value of templated parent which is the CellValuePresenter(<Binding Path="Value" RelativeSource="{RelativeSource TemplatedParent}"/>) This value is being passed as null to my ValueConverter. The other bound value is being passed fine. How can I do this in code behind? I've pasted relevant code sections below.
the XAML
            //<Style x:Key="cvpStyle" TargetType="{x:Type igDP:CellValuePresenter}">
            //<Setter Property="Template">
            //    <Setter.Value>
            //        <ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}">
            //            <Rectangle Name="myRectangle">
            //                <Rectangle.Fill>
            //                    <VisualBrush>
            //                        <VisualBrush.Visual>
            //                            <Label>
            //                                <Label.Content>
            //                                    <MultiBinding Converter="{StaticResource cvpValueChangeConverter}">
            //                                        <Binding Path="Value" RelativeSource="{RelativeSource TemplatedParent}"/>
            //                                        <Binding Path="SelectedItem" ElementName="lbOfferBidFormat" />
the C# code (the binding section)
            MultiBinding multiBinding = new MultiBinding();
            multiBinding.Converter = FindResource("cvpValueChangeConverter") as IMultiValueConverter;
            Binding binding1 = new Binding();
            binding1.Path = new PropertyPath("Value");
            binding1.RelativeSource = RelativeSource.TemplatedParent;
            Binding binding2 = new Binding();
            binding2.Source = ((Main)App.Current.MainWindow).lbOfferBidFormat;
            binding2.Path = new PropertyPath("Text"); //SelectedItem
            multiBinding.Bindings.Add(binding1);
            multiBinding.Bindings.Add(binding2);
