Hi Alex,
My application running under Partial trust environment (XBAP) (Local Intranet).
(Please find the attached solution, used version : 9.2.20092.2023 )
When i trying to choose 'Custom filter' in Label filter icon menu,
it throws the 'Exception has been thrown by the target of an invocation' exception.
I think it requires Full Trust. is it?
But our application is strict to Partial Trust -> Local Intranet.
What i have to do?
Ramesh.P
I got the the following exception when Clicked the Custom.
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.Security.SecurityException: System.Security.Permissions.SecurityPermission at Infragistics.Windows.Helpers.NativeWindowMethods.GetAncestorApi(IntPtr hwnd, Int32 gaFlags) at Infragistics.Windows.Helpers.NativeWindowMethods.IsTopMostApi(IntPtr hwnd) at Infragistics.Windows.Controls.PopupController.get_IsTopMost() at Infragistics.Windows.Controls.PopupController.InitializeChildSource(PresentationSource source) at Infragistics.Windows.Controls.PopupController.OnPopupOpened(Object sender, EventArgs e) at System.Windows.FrameworkElement.RaiseClrEvent(EventPrivateKey key, EventArgs args) at System.Windows.Controls.Primitives.Popup.OnOpened(EventArgs e) at System.Windows.Controls.Primitives.Popup.CreateWindow(Boolean asyncCall) at System.Windows.Controls.Primitives.Popup.OnIsOpenChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, OperationType operationType) at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, OperationType operationType, Boolean isInternal) at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value) at System.Windows.Controls.Primitives.Popup.set_IsOpen(Boolean value) at Infragistics.Windows.Controls.ToolWindowHostPopup.ShowImpl(ToolWindow toolWindow, Boolean activate, Boolean isModal, ShowDialogCallback callback) at Infragistics.Windows.Controls.ToolWindow.ShowDialog(FrameworkElement owner, ShowDialogCallback callback) at Infragistics.Windows.DataPresenter.FieldLayout.ShowCustomFilterSelectionControl(RecordFilter recordFilter, RecordManager recordManager) at Infragistics.Windows.DataPresenter.CustomFilterAction.Execute(Object parameter) at Infragistics.Windows.DataPresenter.RecordFilter.OnExecuteCommand(ICommand command)The type of the first permission that failed was:System.Security.Permissions.SecurityPermissionThe demand was for:<IPermission class="System.Security.Permissions.SecurityPermission, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"version="1"Flags="UnmanagedCode"/>The Zone of the assembly that failed was:MyComputer --- End of inner exception stack trace --- at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) at System.Delegate.DynamicInvokeImpl(Object[] args) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) at System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) at System.Windows.Threading.DispatcherOperation.InvokeImpl() at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state) at System.Threading.ExecutionContext.runTryCode(Object userData) at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Threading.DispatcherOperation.Invoke() at System.Windows.Threading.Dispatcher.ProcessQueue() at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) at System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Boolean isSingleParameter) at System.Windows.Threading.Dispatcher.Invoke(DispatcherPriority priority, Delegate method, Object arg) at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg) at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame) at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame) at System.Windows.Threading.Dispatcher.Run() at System.Windows.Application.RunDispatcher(Object ignore) at System.Windows.Application.StartDispatcherInBrowser(Object unused) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) at System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) at System.Windows.Threading.DispatcherOperation.InvokeImpl() at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state) at System.Threading.ExecutionContext.runTryCode(Object userData) at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Threading.DispatcherOperation.Invoke() at System.Windows.Threading.Dispatcher.ProcessQueue() at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) at System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Boolean isSingleParameter) at System.Windows.Threading.Dispatcher.Invoke(DispatcherPriority priority, Delegate method, Object arg) at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)-----------------------PresentationHost.exe v3.0.6920.1427 built by: SP - c:\WINDOWS\system32\PresentationHost.exentdll.dll v5.1.2600.3520 (xpsp_sp2_gdr.090206-1233) - C:\WINDOWS\system32\ntdll.dllkernel32.dll v5.1.2600.3541 (xpsp_sp2_gdr.090321-1320) - C:\WINDOWS\system32\kernel32.dllSYSFER.DLL v11.0.4202.51 - C:\WINDOWS\SYSTEM32\SYSFER.DLLADVAPI32.dll v5.1.2600.3520 (xpsp_sp2_gdr.090206-1233) - C:\WINDOWS\system32\ADVAPI32.dllRPCRT4.dll v5.1.2600.3555 (xpsp_sp2_gdr.090415-1235) - C:\WINDOWS\system32\RPCRT4.dllSecur32.dll v5.1.2600.3592 (xpsp_sp2_gdr.090622-1453) - C:\WINDOWS\system32\Secur32.dllMSVCR80.dll v8.00.50727.3053 - C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3053_x-ww_b80fa8ca\MSVCR80.dllmsvcrt.dll v7.0.2600.2180 (xpsp_sp2_rtm.040803-2158) - C:\WINDOWS\system32\msvcrt.dllUSER32.dll v5.1.2600.3099 (xpsp_sp2_gdr.070308-0222) - C:\WINDOWS\system32\USER32.dllGDI32.dll v5.1.2600.3466 (xpsp_sp2_gdr.081022-1254) - C:\WINDOWS\system32\GDI32.dllole32.dll v5.1.2600.2726 (xpsp_sp2_gdr.050725-1528) - C:\WINDOWS\system32\ole32.dllmscoree.dll v2.0.50727.3053 (netfxsp.050727-3000) - c:\WINDOWS\system32\mscoree.dllSHLWAPI.dll v6.00.2900.3592 (xpsp_sp2_gdr.090622-1453) - C:\WINDOWS\system32\SHLWAPI.dllurlmon.dll v6.00.2900.3592 (xpsp_sp2_gdr.090622-1453) - C:\WINDOWS\system32\urlmon.dllVERSION.dll v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - C:\WINDOWS\system32\VERSION.dllSHELL32.dll v6.00.2900.3402 (xpsp_sp2_gdr.080702-1233) - C:\WINDOWS\system32\SHELL32.dllWININET.dll v6.00.2900.3592 (xpsp_sp2_gdr.090622-1453) - C:\WINDOWS\system32\WININET.dllCRYPT32.dll v5.131.2600.2180 (xpsp_sp2_rtm.040803-2158) - C:\WINDOWS\system32\CRYPT32.dllMSASN1.dll v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - C:\WINDOWS\system32\MSASN1.dllOLEAUT32.dll v5.1.2600.3266 - C:\WINDOWS\system32\OLEAUT32.dllIMM32.DLL v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - C:\WINDOWS\system32\IMM32.DLLLPK.DLL v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - c:\WINDOWS\system32\LPK.DLLUSP10.dll v1.0420.2600.2180 (xpsp_sp2_rtm.040803-2158) - c:\WINDOWS\system32\USP10.dllcomctl32.dll v6.0 (xpsp.060825-0040) - C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.2982_x-ww_ac3f9c03\comctl32.dlluxtheme.dll v6.00.2900.2180 (xpsp_sp2_rtm.040803-2158) - C:\WINDOWS\system32\uxtheme.dllMSCTF.dll v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - C:\WINDOWS\system32\MSCTF.dllCLBCATQ.DLL v2001.12.4414.308 - c:\WINDOWS\system32\CLBCATQ.DLLCOMRes.dll v2001.12.4414.258 - c:\WINDOWS\system32\COMRes.dllxpsp2res.dll v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - c:\WINDOWS\system32\xpsp2res.dllmlang.dll v6.00.2900.2180 (xpsp_sp2_rtm.040803-2158) - c:\WINDOWS\system32\mlang.dllwsock32.dll v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - c:\WINDOWS\system32\wsock32.dllWS2_32.dll v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - c:\WINDOWS\system32\WS2_32.dllWS2HELP.dll v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - c:\WINDOWS\system32\WS2HELP.dllFwcWsp.dll v4.0 - C:\Program Files\Microsoft Firewall Client 2004\FwcWsp.dllRASAPI32.DLL v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - c:\WINDOWS\system32\RASAPI32.DLLrasman.dll v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - c:\WINDOWS\system32\rasman.dllNETAPI32.dll v5.1.2600.3462 (xpsp_sp2_gdr.081015-1244) - C:\WINDOWS\system32\NETAPI32.dllTAPI32.dll v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - c:\WINDOWS\system32\TAPI32.dllrtutils.dll v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - c:\WINDOWS\system32\rtutils.dllWINMM.dll v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - c:\WINDOWS\system32\WINMM.dllmswsock.dll v5.1.2600.3394 (xpsp_sp2_gdr.080620-1245) - C:\WINDOWS\system32\mswsock.dllhnetcfg.dll v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - c:\WINDOWS\system32\hnetcfg.dllwshtcpip.dll v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - C:\WINDOWS\System32\wshtcpip.dllsensapi.dll v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - c:\WINDOWS\system32\sensapi.dllUSERENV.dll v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - C:\WINDOWS\system32\USERENV.dllDNSAPI.dll v5.1.2600.3394 (xpsp_sp2_gdr.080620-1245) - c:\WINDOWS\system32\DNSAPI.dllrasadhlp.dll v5.1.2600.2938 (xpsp_sp2_gdr.060626-0020) - c:\WINDOWS\system32\rasadhlp.dlldfshim.dll v2.0.50727.3053 (netfxsp.050727-3000) - c:\WINDOWS\system32\dfshim.dllmscorwks.dll v2.0.50727.3603 (GDR.050727-3600) - C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorwks.dllPresentationHostDLL.dll v3.0.6920.1427 built by: SP - c:\WINDOWS\Microsoft.NET\Framework\v3.0\WPF\PresentationHostDLL.dllPSAPI.DLL v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - c:\WINDOWS\system32\PSAPI.DLLactxprxy.dll v6.00.2900.2180 (xpsp_sp2_rtm.040803-2158) - C:\WINDOWS\system32\actxprxy.dllPresentationHostProxy.dll v3.0.6920.1427 built by: SP - c:\WINDOWS\system32\PresentationHostProxy.dllmsctfime.ime v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - C:\WINDOWS\system32\msctfime.imemshtml.dll v6.00.2900.3603 (xpsp_sp2_gdr.090718-1246) - C:\WINDOWS\system32\mshtml.dllmsls31.dll v3.10.349.0 - C:\WINDOWS\system32\msls31.dllSHDOCVW.dll v6.00.2900.3603 (xpsp_sp2_gdr.090718-1246) - C:\WINDOWS\system32\SHDOCVW.dllCRYPTUI.dll v5.131.2600.2180 (xpsp_sp2_rtm.040803-2158) - C:\WINDOWS\system32\CRYPTUI.dllWINTRUST.dll v5.131.2600.2180 (xpsp_sp2_rtm.040803-2158) - C:\WINDOWS\system32\WINTRUST.dllIMAGEHLP.dll v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - C:\WINDOWS\system32\IMAGEHLP.dllWLDAP32.dll v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - C:\WINDOWS\system32\WLDAP32.dllpdm.dll v9.0.21022.8 built by: RTM - C:\Program Files\Common Files\Microsoft Shared\VS7Debug\pdm.dllmsdbg2.dll v9.0.21022.8 built by: RTM - C:\Program Files\Common Files\Microsoft Shared\VS7Debug\msdbg2.dllmsimtf.dll v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - C:\WINDOWS\system32\msimtf.dllmslbui.dll v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - C:\WINDOWS\system32\mslbui.dlljscript.dll v5.6.0.8837 - C:\WINDOWS\system32\jscript.dllImgUtil.dll v6.00.2900.2180 (xpsp_sp2_rtm.040803-2158) - c:\WINDOWS\system32\ImgUtil.dllpngfilt.dll v6.00.2900.3627 (xpsp_sp2_gdr.090918-1238) - C:\WINDOWS\system32\pngfilt.dllmscorlib.ni.dll v2.0.50727.3603 (GDR.050727-3600) - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\mscorlib\7124a40b9998f7b63c86bd1a2125ce26\mscorlib.ni.dllSystem.ni.dll v2.0.50727.3053 (netfxsp.050727-3000) - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System\3de5bd01124463d7862bd173af90bc83\System.ni.dllWindowsBase.ni.dll v3.0.6920.1427 built by: SP - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\WindowsBase\204d6e5b335134f23ca37638b9227ecf\WindowsBase.ni.dllPresentationCore.ni.dll v3.0.6920.1427 built by: SP - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\PresentationCore\94badbd64df59de7da249f71da38b1c2\PresentationCore.ni.dllPresentationFramework.ni.dll v3.0.6920.1500 built by: QFE - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\PresentationFramewo#\58c7ac6b6054038dc9346d7ec8e32b4c\PresentationFramework.ni.dllwpfgfx_v0300.dll v3.0.6920.1500 built by: QFE - c:\WINDOWS\Microsoft.NET\Framework\v3.0\WPF\wpfgfx_v0300.dllPresentationUI.ni.dll v3.0.6920.1427 built by: SP - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\PresentationUI\a3a6f52ce1d09a7bdccc8e7fc664792d\PresentationUI.ni.dllSystem.Deployment.ni.dll v2.0.50727.3053 (netfxsp.050727-3000) - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Deployment\c94a427baa7683f4221b91f90c18461b\System.Deployment.ni.dllshfolder.dll v6.00.2900.2180 (xpsp_sp2_rtm.040803-2158) - c:\WINDOWS\system32\shfolder.dllrsaenh.dll v5.1.2600.2161 (xpsp.040706-1629) - c:\WINDOWS\system32\rsaenh.dllSystem.Configuration.ni.dll v2.0.50727.3053 (netfxsp.050727-3000) - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Configuration\7c743462baccf29b3567b0e3ec9ac134\System.Configuration.ni.dllSystem.Xml.ni.dll v2.0.50727.3082 (QFE.050727-3000) - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Xml\5913d3f81e77194ec833991b1047a532\System.Xml.ni.dlliphlpapi.dll v5.1.2600.2912 (xpsp_sp2_gdr.060519-0003) - c:\WINDOWS\system32\iphlpapi.dllwinrnr.dll v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - C:\WINDOWS\System32\winrnr.dllSystem.Security.ni.dll v2.0.50727.3053 (netfxsp.050727-3000) - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Security\a9e9b885a6601469c4058375cc74d856\System.Security.ni.dllcryptnet.dll v5.131.2600.2180 (xpsp_sp2_rtm.040803-2158) - c:\WINDOWS\system32\cryptnet.dllWINHTTP.dll v5.1.2600.3494 (xpsp_sp2_gdr.081216-1254) - c:\WINDOWS\system32\WINHTTP.dllNTDSAPI.DLL v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - c:\WINDOWS\system32\NTDSAPI.DLLmsv1_0.dll v5.1.2600.3592 (xpsp_sp2_gdr.090622-1453) - C:\WINDOWS\system32\msv1_0.dllcryptdll.dll v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - c:\WINDOWS\system32\cryptdll.dllmshtmled.dll v6.00.2900.3592 (xpsp_sp2_gdr.090622-1453) - C:\WINDOWS\system32\mshtmled.dllSystem.Drawing.ni.dll v2.0.50727.3053 (netfxsp.050727-3000) - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Drawing\abb2ac7e08bee026f857d8fa36f9fe6f\System.Drawing.ni.dllSystem.Windows.Forms.ni.dll v2.0.50727.3053 (netfxsp.050727-3000) - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Windows.Forms\d2ea8d76f015817db1607075812b555f\System.Windows.Forms.ni.dllCabinet.dll v5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) - c:\WINDOWS\system32\Cabinet.dllmscorjit.dll v2.0.50727.3082 (QFE.050727-3000) - C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorjit.dllPresentationFramework.Luna.ni.dll v3.0.6920.1427 built by: SP - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\PresentationFramewo#\3bb4d16b042b72c2c85a0f8ac9d48f28\PresentationFramework.Luna.ni.dllInfragistics3.Wpf.DataPresenter.v9.2.dll v9.2.20092.2023 - C:\Documents and Settings\ravikumar.d\Local Settings\Apps\2.0\MG8WGXMB.TJC\93AJB0WP.DC9\perf..xbap_32572e3ec21ca35e_0001.0000_4d35e70ba687ac0d\Infragistics3.Wpf.DataPresenter.v9.2.dllInfragistics3.Wpf.v9.2.dll v9.2.20092.2023 - C:\Documents and Settings\ravikumar.d\Local Settings\Apps\2.0\MG8WGXMB.TJC\93AJB0WP.DC9\perf..xbap_32572e3ec21ca35e_0001.0000_4d35e70ba687ac0d\Infragistics3.Wpf.v9.2.dllInfragistics3.Wpf.Editors.v9.2.dll v9.2.20092.2023 - C:\Documents and Settings\ravikumar.d\Local Settings\Apps\2.0\MG8WGXMB.TJC\93AJB0WP.DC9\perf..xbap_32572e3ec21ca35e_0001.0000_4d35e70ba687ac0d\Infragistics3.Wpf.Editors.v9.2.dlld3d9.dll v5.03.2600.2180 (xpsp_sp2_rtm.040803-2158) - c:\WINDOWS\system32\d3d9.dlld3d8thk.dll v5.03.2600.2180 (xpsp_sp2_rtm.040803-2158) - c:\WINDOWS\system32\d3d8thk.dllSystem.Data.ni.dll v2.0.50727.3053 (netfxsp.050727-3000) - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Data\694c07365e0fd6bba0bc304d4d2404a7\System.Data.ni.dllSystem.Data.dll v2.0.50727.3053 (netfxsp.050727-3000) - C:\WINDOWS\assembly\GAC_32\System.Data\2.0.0.0__b77a5c561934e089\System.Data.dllSystem.ServiceModel.ni.dll v3.0.4506.2254 (QFE.030729-1900) - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.ServiceModel\06d6eab93282d2b136a377bd50b7c5a9\System.ServiceModel.ni.dllSMDiagnostics.ni.dll v3.0.4506.2152 (SP.030729-0100) - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\SMDiagnostics\7602d7687fb9bd21cd9ae60d2b187c99\SMDiagnostics.ni.dllSystem.Runtime.Serialization.ni.dll v3.0.4506.2152 (SP.030729-0100) - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Runtime.Seri#\67ad55827f2542552b576170f0a7dc56\System.Runtime.Serialization.ni.dllSystem.Web.ni.dll v2.0.50727.3082 (QFE.050727-3000) - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Web\5cea03cfb008f2eac1439a9905467f37\System.Web.ni.dllSystem.WorkflowServices.ni.dll v3.5.594.1152 - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.WorkflowServ#\fa48917b13629d8effa80dd4a2f2973d\System.WorkflowServices.ni.dllSystem.ServiceModel.Web.ni.dll v3.5.594.1152 - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.ServiceModel#\e182695d05ea57257568bc5f3208aca7\System.ServiceModel.Web.ni.dllMicrosoft.VisualStudio.Diagnostics.ServiceModelSink.dll v9.0.21022.8 - C:\WINDOWS\assembly\GAC_MSIL\Microsoft.VisualStudio.Diagnostics.ServiceModelSink\3.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualStudio.Diagnostics.ServiceModelSink.dllSystem.IdentityModel.ni.dll v3.0.4506.2152 (SP.030729-0100) - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.IdentityModel\c3b18fef5c6dc3bcdbe5df699fd21a55\System.IdentityModel.ni.dlldiasymreader.dll v8.0.50727.3053 (netfxsp.050727-3000) - C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\diasymreader.dllPresentationNative_v0300.dll v3.0.6920.1427 built by: SP - c:\WINDOWS\system32\PresentationNative_v0300.dllUIAutomationTypes.ni.dll v3.0.6920.1427 built by: SP - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\UIAutomationTypes\6f488b7644dc50a083868e91a4014466\UIAutomationTypes.ni.dllUIAutomationCore.dll v6.0.6001.17014 (lh_tools_devdiv_wpf.071009-1109) - c:\WINDOWS\system32\UIAutomationCore.dllOLEACC.dll v4.2.5406.0 (xpclient.010817-1148) - c:\WINDOWS\system32\OLEACC.dllMSVCP60.dll v6.02.3104.0 - c:\WINDOWS\system32\MSVCP60.dllSystem.Core.ni.dll v3.5.30729.1 built by: SP - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\System.Core\c0a42d2ad8a4078040b334f6770ea11f\System.Core.ni.dllUIAutomationProvider.ni.dll v3.0.6920.1427 built by: SP - C:\WINDOWS\assembly\NativeImages_v2.0.50727_32\UIAutomationProvider\b4a9e413d5cd6d6ec2d50aa05381e293\UIAutomationProvider.ni.dllWindowsCodecs.dll v6.0.5840.16388 (winmain(wmbla).061024-1209) - c:\WINDOWS\system32\WindowsCodecs.dll
