We have a problem with XamDockManager and the TabGroupPane.
Our application creates some ContentPanes and adds them to the TabGroupPane.
Sometimes if you click on another tab, the new tab is selected and then instantly the previously selected tab becomes selected again.
Do you have an idea how to solve this problem?
phyres said:Why is the selected Tab changed if I only move the mouse in the selected TabHeader?
Here are the stacktrace logs if I click and move the mouse between the down and up like you described it.
Why is the selected Tab changed if I only move the mouse in the selected TabHeader?2009-11-26 10:56:56,025 [9] DEBUG Infragistics.Windows.DockManager.ContentPane - bei xxx.Pims.MainWindow.contentPane_GotKeyboardFocus(Object sender, KeyboardFocusChangedEventArgs e) bei System.Windows.Input.KeyboardFocusChangedEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget) bei System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target) bei System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs) bei System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) bei System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args) bei System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted) bei System.Windows.Input.InputManager.ProcessStagingArea() bei System.Windows.Input.InputManager.ProcessInput(InputEventArgs input) bei System.Windows.Input.KeyboardDevice.ChangeFocus(DependencyObject focus, Int32 timestamp) bei System.Windows.Input.KeyboardDevice.TryChangeFocus(DependencyObject newFocus, IKeyboardInputProvider keyboardInputProvider, Boolean askOld, Boolean askNew, Boolean forceToNullIfFailed) bei System.Windows.Input.KeyboardDevice.Focus(DependencyObject focus, Boolean askOld, Boolean askNew) bei System.Windows.Input.KeyboardDevice.Focus(IInputElement element) bei System.Windows.Interop.HwndKeyboardInputProvider.FilterMessage(IntPtr hwnd, Int32 message, IntPtr wParam, IntPtr lParam, Boolean& handled) bei System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) bei MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) bei MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) bei System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter) bei System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) bei System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) bei System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Boolean isSingleParameter) bei System.Windows.Threading.Dispatcher.Invoke(DispatcherPriority priority, Delegate method, Object arg) bei MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) bei MS.Win32.UnsafeNativeMethods.CallWindowProc(IntPtr wndProc, IntPtr hWnd, Int32 msg, IntPtr wParam, IntPtr lParam) bei MS.Win32.HwndSubclass.DefWndProcWrapper(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) bei MS.Win32.UnsafeNativeMethods.CallWindowProc(IntPtr wndProc, IntPtr hWnd, Int32 msg, IntPtr wParam, IntPtr lParam) bei MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) bei MS.Win32.UnsafeNativeMethods.IntGetMessageW(MSG& msg, HandleRef hWnd, Int32 uMsgFilterMin, Int32 uMsgFilterMax) bei MS.Win32.UnsafeNativeMethods.GetMessageW(MSG& msg, HandleRef hWnd, Int32 uMsgFilterMin, Int32 uMsgFilterMax) bei System.Windows.Threading.Dispatcher.GetMessage(MSG& msg, IntPtr hwnd, Int32 minMessage, Int32 maxMessage) bei System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame) bei System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame) bei System.Windows.Threading.Dispatcher.Run() bei System.Windows.Application.RunDispatcher(Object ignore) bei System.Windows.Application.RunInternal(Window window) bei System.Windows.Application.Run(Window window) bei System.Windows.Application.Run() bei xxx.Pims.App.Main() bei System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args) bei System.AppDomain.nExecuteAssembly(Assembly assembly, String[] args) bei System.Runtime.Hosting.ManifestRunner.Run(Boolean checkAptModel) bei System.Runtime.Hosting.ManifestRunner.ExecuteAsAssembly() bei System.Runtime.Hosting.ApplicationActivator.CreateInstance(ActivationContext activationContext, String[] activationCustomData) bei System.Runtime.Hosting.ApplicationActivator.CreateInstance(ActivationContext activationContext) bei System.Activator.CreateInstance(ActivationContext activationContext) bei Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssemblyDebugInZone() bei System.Threading.ThreadHelper.ThreadStart_Context(Object state) bei System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) bei System.Threading.ThreadHelper.ThreadStart()2009-11-26 10:56:56,035 [9] DEBUG Infragistics.Windows.DockManager.ContentPane - bei xxx.Pims.MainWindow.contentPane_GotKeyboardFocus(Object sender, KeyboardFocusChangedEventArgs e) bei System.Windows.Input.KeyboardFocusChangedEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget) bei System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target) bei System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs) bei System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) bei System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args) bei System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted) bei System.Windows.Input.InputManager.ProcessStagingArea() bei System.Windows.Input.InputManager.ProcessInput(InputEventArgs input) bei System.Windows.Input.KeyboardDevice.ChangeFocus(DependencyObject focus, Int32 timestamp) bei System.Windows.Input.KeyboardDevice.TryChangeFocus(DependencyObject newFocus, IKeyboardInputProvider keyboardInputProvider, Boolean askOld, Boolean askNew, Boolean forceToNullIfFailed) bei System.Windows.Input.KeyboardDevice.Focus(DependencyObject focus, Boolean askOld, Boolean askNew) bei System.Windows.Input.KeyboardDevice.Focus(IInputElement element) bei System.Windows.UIElement.Focus() bei Infragistics.Windows.DockManager.ContentPane.ActivateInternalImpl(Boolean force, Boolean bringIntoView) bei Infragistics.Windows.DockManager.ContentPane.ActivateInternal(Boolean force, Boolean bringIntoView) bei Infragistics.Windows.DockManager.PaneTabItem.OnMouseDown(MouseButtonEventArgs e) bei System.Windows.UIElement.OnMouseDownThunk(Object sender, MouseButtonEventArgs e) bei System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget) bei System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target) bei System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs) bei System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) bei System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args) bei System.Windows.ContentElement.RaiseEvent(RoutedEventArgs args, Boolean trusted) bei System.Windows.Input.InputManager.ProcessStagingArea() bei System.Windows.Input.InputManager.ProcessInput(InputEventArgs input) bei System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport) bei System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel) bei System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) bei System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) bei MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) bei MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) bei System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter) bei System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) bei System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) bei System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Boolean isSingleParameter) bei System.Windows.Threading.Dispatcher.Invoke(DispatcherPriority priority, Delegate method, Object arg) bei MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) bei MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg) bei System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame) bei System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame) bei System.Windows.Threading.Dispatcher.Run() bei System.Windows.Application.RunDispatcher(Object ignore) bei System.Windows.Application.RunInternal(Window window) bei System.Windows.Application.Run(Window window) bei System.Windows.Application.Run() bei xxx.Pims.App.Main() bei System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args) bei System.AppDomain.nExecuteAssembly(Assembly assembly, String[] args) bei System.Runtime.Hosting.ManifestRunner.Run(Boolean checkAptModel) bei System.Runtime.Hosting.ManifestRunner.ExecuteAsAssembly() bei System.Runtime.Hosting.ApplicationActivator.CreateInstance(ActivationContext activationContext, String[] activationCustomData) bei System.Runtime.Hosting.ApplicationActivator.CreateInstance(ActivationContext activationContext) bei System.Activator.CreateInstance(ActivationContext activationContext) bei Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssemblyDebugInZone() bei System.Threading.ThreadHelper.ThreadStart_Context(Object state) bei System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) bei System.Threading.ThreadHelper.ThreadStart()2009-11-26 10:56:56,281 [9] DEBUG Infragistics.Windows.DockManager.ContentPane - bei xxx.Pims.MainWindow.contentPane_GotKeyboardFocus(Object sender, KeyboardFocusChangedEventArgs e) bei System.Windows.Input.KeyboardFocusChangedEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget) bei System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target) bei System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs) bei System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) bei System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args) bei System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted) bei System.Windows.Input.InputManager.ProcessStagingArea() bei System.Windows.Input.InputManager.ProcessInput(InputEventArgs input) bei System.Windows.Input.KeyboardDevice.ChangeFocus(DependencyObject focus, Int32 timestamp) bei System.Windows.Input.KeyboardDevice.TryChangeFocus(DependencyObject newFocus, IKeyboardInputProvider keyboardInputProvider, Boolean askOld, Boolean askNew, Boolean forceToNullIfFailed) bei System.Windows.Input.KeyboardDevice.Focus(DependencyObject focus, Boolean askOld, Boolean askNew) bei System.Windows.Input.KeyboardDevice.Focus(IInputElement element) bei System.Windows.UIElement.Focus() bei Infragistics.Windows.DockManager.ContentPane.ActivateInternalImpl(Boolean force, Boolean bringIntoView) bei Infragistics.Windows.DockManager.ContentPane.ActivateInternal(Boolean force, Boolean bringIntoView) bei Infragistics.Windows.DockManager.TabGroupPane.VerifyActivePanes() bei Infragistics.Windows.DockManager.TabGroupPane.OnSelectionChanged(SelectionChangedEventArgs e) bei System.Windows.Controls.Primitives.Selector.InvokeSelectionChanged(List`1 unselectedItems, List`1 selectedItems) bei System.Windows.Controls.Primitives.Selector.SelectionChanger.End() bei System.Windows.Controls.Primitives.Selector.SetSelectedHelper(Object item, FrameworkElement UI, Boolean selected) bei System.Windows.Controls.Primitives.Selector.NotifyIsSelectedChanged(FrameworkElement container, Boolean selected, RoutedEventArgs e) bei System.Windows.Controls.Primitives.Selector.OnSelected(Object sender, RoutedEventArgs e) bei System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs) bei System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) bei System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args) bei System.Windows.UIElement.RaiseEvent(RoutedEventArgs e) bei System.Windows.Controls.TabItem.OnSelected(RoutedEventArgs e) bei Infragistics.Windows.Controls.TabItemEx.OnSelected(RoutedEventArgs e) bei System.Windows.Controls.TabItem.OnIsSelectedChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) bei System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) bei System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) bei System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) bei System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, OperationType operationType) bei System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, OperationType operationType, Boolean isInternal) bei System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value) bei System.Windows.Controls.TabItem.set_IsSelected(Boolean value) bei System.Windows.Controls.TabControl.OnItemsChanged(NotifyCollectionChangedEventArgs e) bei Infragistics.Windows.DockManager.TabGroupPane.OnItemsChanged(NotifyCollectionChangedEventArgs e) bei System.Windows.Controls.ItemsControl.OnItemCollectionChanged(Object sender, NotifyCollectionChangedEventArgs e) bei System.Collections.Specialized.NotifyCollectionChangedEventHandler.Invoke(Object sender, NotifyCollectionChangedEventArgs e) bei System.Windows.Data.CollectionView.OnCollectionChanged(NotifyCollectionChangedEventArgs args) bei System.Windows.Controls.ItemCollection.System.Windows.IWeakEventListener.ReceiveWeakEvent(Type managerType, Object sender, EventArgs e) bei System.Windows.WeakEventManager.DeliverEventToList(Object sender, EventArgs args, ListenerList list) bei System.Windows.WeakEventManager.DeliverEvent(Object sender, EventArgs args) bei System.Collections.Specialized.CollectionChangedEventManager.OnCollectionChanged(Object sender, NotifyCollectionChangedEventArgs args) bei System.Windows.Data.CollectionView.OnCollectionChanged(NotifyCollectionChangedEventArgs args) bei MS.Internal.Controls.InnerItemCollectionView._RemoveAt(Int32 index, Int32 indexR, Object item) bei MS.Internal.Controls.InnerItemCollectionView.RemoveAt(Int32 index) bei System.Windows.Controls.ItemCollection.RemoveAt(Int32 removeIndex) bei Infragistics.Windows.DockManager.TabGroupPane.Infragistics.Windows.DockManager.IContentPaneContainer.RemoveContentPane(ContentPane pane, Boolean replaceWithPlaceholder) bei Infragistics.Windows.DockManager.Dragging.AddToGroupActionBase.PerformAction(DragManager dragManager, Boolean isPreview) bei Infragistics.Windows.DockManager.Dragging.DragManager.EndDrag(Boolean cancel) bei Infragistics.Windows.DockManager.Dragging.DragManager.OnDragElementMouseUp(Object sender, MouseButtonEventArgs e) bei System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget) bei System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target) bei System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs) bei System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) bei System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args) bei System.Windows.ContentElement.RaiseEvent(RoutedEventArgs args, Boolean trusted) bei System.Windows.Input.InputManager.ProcessStagingArea() bei System.Windows.Input.InputManager.ProcessInput(InputEventArgs input) bei System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport) bei System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel) bei System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) bei System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) bei MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) bei MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) bei System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter) bei System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) bei System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) bei System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Boolean isSingleParameter) bei System.Windows.Threading.Dispatcher.Invoke(DispatcherPriority priority, Delegate method, Object arg) bei MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) bei MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg) bei System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame) bei System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame) bei System.Windows.Threading.Dispatcher.Run() bei System.Windows.Application.RunDispatcher(Object ignore) bei System.Windows.Application.RunInternal(Window window) bei System.Windows.Application.Run(Window window) bei System.Windows.Application.Run() bei xxx.Pims.App.Main() bei System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args) bei System.AppDomain.nExecuteAssembly(Assembly assembly, String[] args) bei System.Runtime.Hosting.ManifestRunner.Run(Boolean checkAptModel) bei System.Runtime.Hosting.ManifestRunner.ExecuteAsAssembly() bei System.Runtime.Hosting.ApplicationActivator.CreateInstance(ActivationContext activationContext, String[] activationCustomData) bei System.Runtime.Hosting.ApplicationActivator.CreateInstance(ActivationContext activationContext) bei System.Activator.CreateInstance(ActivationContext activationContext) bei Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssemblyDebugInZone() bei System.Threading.ThreadHelper.ThreadStart_Context(Object state) bei System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) bei System.Threading.ThreadHelper.ThreadStart()2009-11-26 10:56:56,307 [9] DEBUG Infragistics.Windows.DockManager.ContentPane - bei xxx.Pims.MainWindow.contentPane_GotKeyboardFocus(Object sender, KeyboardFocusChangedEventArgs e) bei System.Windows.Input.KeyboardFocusChangedEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget) bei System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target) bei System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs) bei System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) bei System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args) bei System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted) bei System.Windows.Input.InputManager.ProcessStagingArea() bei System.Windows.Input.InputManager.ProcessInput(InputEventArgs input) bei System.Windows.Input.KeyboardDevice.ChangeFocus(DependencyObject focus, Int32 timestamp) bei System.Windows.Input.KeyboardDevice.TryChangeFocus(DependencyObject newFocus, IKeyboardInputProvider keyboardInputProvider, Boolean askOld, Boolean askNew, Boolean forceToNullIfFailed) bei System.Windows.Input.KeyboardDevice.Focus(DependencyObject focus, Boolean askOld, Boolean askNew) bei System.Windows.Input.KeyboardDevice.Focus(IInputElement element) bei System.Windows.UIElement.Focus() bei Infragistics.Windows.DockManager.ContentPane.ActivateInternalImpl(Boolean force, Boolean bringIntoView) bei Infragistics.Windows.DockManager.ContentPane.ActivateInternal(Boolean force, Boolean bringIntoView) bei Infragistics.Windows.DockManager.XamDockManager.OnGotKeyboardFocus(KeyboardFocusChangedEventArgs e) bei System.Windows.UIElement.OnGotKeyboardFocusThunk(Object sender, KeyboardFocusChangedEventArgs e) bei System.Windows.Input.KeyboardFocusChangedEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget) bei System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target) bei System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs) bei System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) bei System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args) bei System.Windows.ContentElement.RaiseEvent(RoutedEventArgs args, Boolean trusted) bei System.Windows.Input.InputManager.ProcessStagingArea() bei System.Windows.Input.InputManager.ProcessInput(InputEventArgs input) bei System.Windows.Input.KeyboardDevice.ChangeFocus(DependencyObject focus, Int32 timestamp) bei System.Windows.Input.KeyboardDevice.TryChangeFocus(DependencyObject newFocus, IKeyboardInputProvider keyboardInputProvider, Boolean askOld, Boolean askNew, Boolean forceToNullIfFailed) bei System.Windows.Input.KeyboardDevice.Focus(DependencyObject focus, Boolean askOld, Boolean askNew) bei System.Windows.Input.KeyboardDevice.Focus(IInputElement element) bei System.Windows.ContentElement.Focus() bei Infragistics.Windows.DockManager.Dragging.DragManager.EndDrag(Boolean cancel) bei Infragistics.Windows.DockManager.Dragging.DragManager.OnDragElementMouseUp(Object sender, MouseButtonEventArgs e) bei System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget) bei System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target) bei System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs) bei System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) bei System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args) bei System.Windows.ContentElement.RaiseEvent(RoutedEventArgs args, Boolean trusted) bei System.Windows.Input.InputManager.ProcessStagingArea() bei System.Windows.Input.InputManager.ProcessInput(InputEventArgs input) bei System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport) bei System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel) bei System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) bei System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) bei MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) bei MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) bei System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter) bei System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) bei System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) bei System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Boolean isSingleParameter) bei System.Windows.Threading.Dispatcher.Invoke(DispatcherPriority priority, Delegate method, Object arg) bei MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) bei MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg) bei System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame) bei System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame) bei System.Windows.Threading.Dispatcher.Run() bei System.Windows.Application.RunDispatcher(Object ignore) bei System.Windows.Application.RunInternal(Window window) bei System.Windows.Application.Run(Window window) bei System.Windows.Application.Run() bei xxx.Pims.App.Main() bei System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args) bei System.AppDomain.nExecuteAssembly(Assembly assembly, String[] args) bei System.Runtime.Hosting.ManifestRunner.Run(Boolean checkAptModel) bei System.Runtime.Hosting.ManifestRunner.ExecuteAsAssembly() bei System.Runtime.Hosting.ApplicationActivator.CreateInstance(ActivationContext activationContext, String[] activationCustomData) bei System.Runtime.Hosting.ApplicationActivator.CreateInstance(ActivationContext activationContext) bei System.Activator.CreateInstance(ActivationContext activationContext) bei Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssemblyDebugInZone() bei System.Threading.ThreadHelper.ThreadStart_Context(Object state) bei System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) bei System.Threading.ThreadHelper.ThreadStart()2009-11-26 10:56:59,767 [9] DEBUG Infragistics.Windows.DockManager.ContentPane - bei xxx.Pims.MainWindow.contentPane_GotKeyboardFocus(Object sender, KeyboardFocusChangedEventArgs e) bei System.Windows.Input.KeyboardFocusChangedEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget) bei System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target) bei System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs) bei System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) bei System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args) bei System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted) bei System.Windows.Input.InputManager.ProcessStagingArea() bei System.Windows.Input.InputManager.ProcessInput(InputEventArgs input) bei System.Windows.Input.KeyboardDevice.ChangeFocus(DependencyObject focus, Int32 timestamp) bei System.Windows.Input.KeyboardDevice.TryChangeFocus(DependencyObject newFocus, IKeyboardInputProvider keyboardInputProvider, Boolean askOld, Boolean askNew, Boolean forceToNullIfFailed) bei System.Windows.Input.KeyboardDevice.Focus(DependencyObject focus, Boolean askOld, Boolean askNew) bei System.Windows.Input.KeyboardDevice.Focus(IInputElement element) bei System.Windows.Interop.HwndKeyboardInputProvider.FilterMessage(IntPtr hwnd, Int32 message, IntPtr wParam, IntPtr lParam, Boolean& handled) bei System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) bei MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) bei MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) bei System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter) bei System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) bei System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) bei System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Boolean isSingleParameter) bei System.Windows.Threading.Dispatcher.Invoke(DispatcherPriority priority, Delegate method, Object arg) bei MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) bei MS.Win32.UnsafeNativeMethods.CallWindowProc(IntPtr wndProc, IntPtr hWnd, Int32 msg, IntPtr wParam, IntPtr lParam) bei MS.Win32.HwndSubclass.DefWndProcWrapper(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) bei MS.Win32.UnsafeNativeMethods.CallWindowProc(IntPtr wndProc, IntPtr hWnd, Int32 msg, IntPtr wParam, IntPtr lParam) bei MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) bei MS.Win32.UnsafeNativeMethods.IntGetMessageW(MSG& msg, HandleRef hWnd, Int32 uMsgFilterMin, Int32 uMsgFilterMax) bei MS.Win32.UnsafeNativeMethods.GetMessageW(MSG& msg, HandleRef hWnd, Int32 uMsgFilterMin, Int32 uMsgFilterMax) bei System.Windows.Threading.Dispatcher.GetMessage(MSG& msg, IntPtr hwnd, Int32 minMessage, Int32 maxMessage) bei System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame) bei System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame) bei System.Windows.Threading.Dispatcher.Run() bei System.Windows.Application.RunDispatcher(Object ignore) bei System.Windows.Application.RunInternal(Window window) bei System.Windows.Application.Run(Window window) bei System.Windows.Application.Run() bei xxx.Pims.App.Main() bei System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args) bei System.AppDomain.nExecuteAssembly(Assembly assembly, String[] args) bei System.Runtime.Hosting.ManifestRunner.Run(Boolean checkAptModel) bei System.Runtime.Hosting.ManifestRunner.ExecuteAsAssembly() bei System.Runtime.Hosting.ApplicationActivator.CreateInstance(ActivationContext activationContext, String[] activationCustomData) bei System.Runtime.Hosting.ApplicationActivator.CreateInstance(ActivationContext activationContext) bei System.Activator.CreateInstance(ActivationContext activationContext) bei Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssemblyDebugInZone() bei System.Threading.ThreadHelper.ThreadStart_Context(Object state) bei System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) bei System.Threading.ThreadHelper.ThreadStart()
Is it possible that during that click you are moving the mouse between the down and the up such that a drag operation is occuring? If not then can you post the sample with some steps to reproduce the issue? Also, what version are you using?
I am having the same problem and I have nothing in the codebehind and no content. It happens when I click quickly.
I remember a problem like this a while back when a tab contained a windowsformshost but that was fixed quite a while ago. Do you have a sample that reproduces the problem? If not, maybe it would be possible to output the Environment.StackTrace from the GotKeyboardFocus of the element within that other pane that is getting focus back? This might help to indicate what is happening when the focus is shifting back.
